Prime scarcity at dealers
Discussion in 'Prime Main Forum (2017-2022)' started by Welshdog, Nov 1, 2019.
  1. fuzzy1
    10,337
    I think you are still missing a state. Look beyond that province.
    jerrymildred and davecook89t like this.
  2. El Dobro
    El Dobro A Member
    7,079
    3,259
    No bet. When I went to look at PiPs when they first came out, the dealer had a pile of the and not one was charged.
  3. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    My salesperson went out to check that the 12V battery wasn't dead before we went for a test drive.
    But with the manufacturer's rebate they were offering at the time, I didn't care one bit.
  4. davecook89t
    davecook89t Senior Member
    1,076
    812
    Washington State, Florida
    Four Touring
    I said a couple others, then changed it to 4 (others), including Hawaii. I did not forget about Alaska.
    fuzzy1 likes this.
  5. fuzzy1
    10,337
    I read 4 there as a total, not as others.
    If one mashes together some of the recent controversies and conspiracy theories about citizenship and birth, then someone might challenge my citizenship because my mother was born in Alaska when it was not a state. :)
    davecook89t likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,145
    Tampa, FL
    I wouldn't let it set all charged up waiting for someone to want to test drive it either. Not good for the battery. But if they know you're coming, it would be nice of them to put some juice in it before you get there even it it's not a full charge.
  7. El Dobro
    El Dobro A Member
    7,079
    3,259
    I wanted to see what it was like on the battery, being the point of the PiP. When I went to the Chevy dealer to drop my friend off, I had no intention of buying a Volt. The salesman asked me if I wanted to take a test drive and after asking, he told me they were all charged up, so just pick one out.
    jerrymildred likes this.
  8. El Dobro
    El Dobro A Member
    7,079
    3,259
    Oh, and there was maybe 1/8 of a tank of gas in the PiP. I hit a gas station on the way home with it. The Volt tank was full. ;)
  9. bisco
    51,519
    that's really helped to sell volts and bolts (y)
  10. jerrymildred
    11,517
    14,145
    Tampa, FL
    Yeah, it seems like they don't want you to buy one unless you really really really want one. :(
  11. El Dobro
    El Dobro A Member
    7,079
    3,259
    The icing on the cake was that they scratched up the window removing the sticker and had to order a new one. :rolleyes:
  12. schja01
    schja01 Senior Member
    1,827
    1,217
    Chicagoland
    2024 Prius
    Limited AWD-e
    I thought the PP reserved the top and bottom 20% of battery capacity so an apparently fully charged battery is really at 80ish percent charged. Maybe apples to oranges but Apple recommends storing their devices 80% charged if you don’t plan on using them for a while.
  13. jerrymildred
    11,517
    14,145
    Tampa, FL
    Yikes!! I'll bet you'll be dashing back there for your next car, el, @El Dobro? :eek:
    The 20-80 is for while in use in use. Storing at 80% is not good according to the manual. This battery is somewhat more costly to replace than a phone battery.
    schja01 likes this.
  14. schja01
    1,827
    1,217
    Chicagoland
    2024 Prius
    Limited AWD-e
    Mine came with a full tank. The window sticker even says full tank if gas. It’s a Toyota perk.
  15. bisco
    51,519
    My salesman thought it was already charged because the icon was almost full
  16. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    Do you guys think inventory will get very low soon?
  17. bisco
    51,519
  18. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    There is currently a global shortage of automotive electronics, so a car like the Prius that uses a lot of electronics may be hard to manufacture. However I suspect dealer inventory is high, right now as gas prices in the US are low.
    Because buyers have no long term memory, low gas prices keep hybrid prices down.
    BiomedO1 likes this.
  19. bisco
    51,519
    are you serious jumbo? gas prices are through the roof!
  20. fuzzy1
    10,337
    Are you kidding? They are merely where they were 2 years ago, below 3 years ago, and below the 10 year average. And certainly below the through-the-roof prices of 2008 that put me on a path to getting a Prius.
    But people have short memories ...
    john1701a and jerrymildred like this.
