Prius Abs Brake Actuator
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mike Jones, Jan 17, 2020.
  1. Mike Jones
    Mike Jones New Member
    San Francisco
    My abs actuator on my 2008 prius recently failed and I'm looking into getting used parts however there seems to be 3 different part numbers for this part depending on year. I know that 44500-47141 works on all models but they are hard to find used. I have found many 44500-47090 and was wondering if 44500-47090 will work for my 2008 prius. My prius is base trim if that helps. Im currently looking into getting the actuator from a 2009 prius to put into mine.
  2. Bcmullen95
    Bcmullen95 New Member
    From my understanding you want to keep the part number the same.
