Buzzing sound when using defrost
Discussion in 'Prime Main Forum (2017-2022)' started by MommysPrius, Feb 5, 2020.
  1. MommysPrius
    MommysPrius New Member
    25
    Vancouver, Canada
    2019 Prius Prime
    I'm quite late to post this but my Prime has always made a buzzing noise when I use the defrost. (I often have to use this option because I notice when I use just the regular heat my windows starts to slowly steam up)
    When I turn it off, my car is silent again.
    Is this buzzing noise normal or should I get it checked out? I'm pretty sure my car has always made a buzzing noise in defrost mode since the day I bought the car. Thought it was a normal thing, but I'm finding it annoying these days lol.
    Thank you in advance! Oh, and no I don't have the auto climate control on.
  2. schja01
    schja01 Senior Member
    1,814
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    The Heat Pump makes a buzzing sound. Could that be it?
  3. MommysPrius
    25
    Vancouver, Canada
    2019 Prius Prime
    I don't have a clue. Does the heat pump normally make a constant buzzing noise?
  4. schja01
    1,814
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    Buzzing? Mine sounds like the compressor on my home HVAC condenser which could be interpreted as a buzzing.
    Yes it makes the sound as long as the Heat Pump is running and I "think" using defrost is one thing that will cause it to run.
    Having said that, in my case the sound is more noticeable outside than in the cabin.
    #4 schja01, Feb 5, 2020
    MommysPrius likes this.
  5. Trollbait
    12,313
    With just turning on the fan, with temp turned down so heat isn't called for, is the same noise made with the air flow to the windshield, or at all?
  6. FuelMiser
    FuelMiser Senior Member
    1,338
    918
    Monument, CO
    You'd probably avoid steaming up the windows if you leave AUTO ON, which includes A/C ON. This dehumidifies the air, causing the inside of the windows to stay clear.
    I would only use DEFROST when there is ice on the outside of the windshield...
  7. bisco
    51,029
    baseball card in the spokes
  8. MommysPrius
    25
    Vancouver, Canada
    2019 Prius Prime
    Sounds like my car.
  9. MommysPrius
    25
    Vancouver, Canada
    2019 Prius Prime
    I'm used to not running Auto on because it uses air conditioning in my other full gasoline cars in the past. Thus, taking more fuel lol.
  10. FuelMiser
    1,338
    918
    Monument, CO
    A/C in the Prius is electric, not engine driven, so no drag on the engine. I'd also imagine that the front defroster in the Prime uses more energy than the A/C, so I suggest you rethink your bias.
  11. MommysPrius
    25
    Vancouver, Canada
    2019 Prius Prime
    I didn't know it was different for our cars. I just knew it would take more gas in gasoline cars using A/C. Good to know, thank you. I'll try that on my next drive
