What's better - powering off Prius, or leaving on when waiting for someone?
Discussion in 'Gen 2 Prius Technical Discussion' started by 2006priusowner, Sep 23, 2006.
  1. 2006priusowner
    2006priusowner Junior Member
    I can't seem to find any input on when it makes sense to power off the Prius while doing errands. Any insights would be appreciated...
    Scenario: Drove to pick up someone, but had to wait 5 - 10 minutes.
    Question: Is it better to power off, or just put it into park with car powered up?
    Hypothesis: Prius start up consumes some gas, but if you leave car powered on and parked, the car is just sitting, not consuming gas or electricity. So, if you are staying with the car during while you wait, just leave the car powered up?
    Any thoughts?
  2. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Personally, I think it depends on the drain you are putting on the battery.
    If you're sitting there running the A/C, you will certainly drain the battery. If the battery was low to begin with, the engine will kick in. If you started with a good state of charge (SoC) then you have nothing to worry about.
    Besides, even if the engine kicks in, it won't run very long in the grand scheme of things. And how can you possibly listen to the kick-nice person techno Prius-pumping music of DJ Kevin Foreman with the car powered down. :D
  3. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    Rather than the drain on the battery, a more important factor is the conditions outside. Here in Florida, if you truy and sit in a car for 10 minutes with no AC...
    For me, it's all about my personal comfort. I would much rather sit there with the AC on and some good tunes to sing along to.
    Honestly, the amount of gas you would use is so minimal. THe ICE would be off most of the time (unless the battery was already low) and would only come on if needed. Once the need was over, ICE is off again.
  4. SoopahMan
    SoopahMan Member
    118
    For a short wait like 5 minutes, the only thing you're really playing with at that point is the coolant. If you hit the power button at the start of those 5 minutes, the electric pump moves the coolant into a thermos to keep it as hot as possible for when you switch it back on. So, you could say that switching it off maintains the temperature of the system fluids better than leaving it on.
    On the other hand, turning it off then on is going to cause the Prius to go through its usual startup steps, including running the engine in its most wasteful state - generating electricity at a stand-still - to get those fluids pumping through it again. So you might view that step as a waste of gas.
    Overall I bet you net out the same, but it's an interesting topic of discussion anyway.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    It depends upon comfort issues and how long the wait will be.
    If <5 min I typically leave it in READY to avoid the start-up/warm-up routine. If >10min. I'll power down then up into ACC to listen to music unless it's super hot and I want to run AC, in which case I'd leave it in READY.
  6. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    If I'm making a true short stop, for example pulling into a convenience store to pick up a soda, I'll shut the AC and MFD off, use the metal key to lock the door, and just leave it that way -- no wasteful start up sequence, and very little power used (primarily from AC off, I turn off the display so as not to draw unwanted attention). When I return, the car is in almost the same state as when I left it. I've actually had a half dozen "old fashioned" metal keys cut from the "secret key" hidden in the fob. I have one on my keychain for just this purpose. The others are scattered about, home, office, and a couple other "key" locations, to facilitate emergency entry on the day when I manage to lock my fob in the car.
  7. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
    <div class='quotetop'>QUOTE(ekpolk @ Sep 23 2006, 08:28 AM) [snapback]323849[/snapback]</div>
    But if you haven't got SKS and you always have to insert the fob to start the car, would you be able to start the car if you lost the fob and had only a metal key?
  8. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    <_< "Power Down while waiting..."
    Well, that's an individual preference and decision. If the ICE is warmed up, I generally leave it in "READY" mode with the "PARK" pawls engaged for a wait of <5 minutes. For a wait 10+ minutes, I will power down.
  9. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(2006PriusOwner @ Sep 22 2006, 09:21 PM) [snapback]323755[/snapback]</div>
    For just a couple of minutes, I'll leave it on if I'm in the car. More than that, I shut it down.
    Don't pretend that the car doesn't use electricity or gas when just sitting there though! It uses both even when doing nothing (gas is used to recharge the battery that IS being used when sitting idle - in fact, there is no real "electricity component to even discuss - all the energy comes from gasoline ultimately). No, it isn't much, but if you leave the car ON for an extended period, you'll have the gas engine kicking on to recharge the ever-draining battery.
