Oil Pan replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Feb 10, 2020.
  1. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    Agree. No information of any leak provided, oil pan fund can be used for wine.
    Salamander_King likes this.
  2. Mendel Leisk
    40,459
    Driving with an iffy engine oil drain bolt would drive me to drink...
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,343
    2,337
    Taylors, SC
    #43 Georgina Rudkus, Feb 12, 2020
  4. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    No not at this point The oil plug is not tightening like it used to with the gasket on
  5. Salamander_King
    Salamander_King Senior Member
    11,004
    8,925
    New England
    Sounds like you have a few threads left on that oil pan nut. I think changing the oil pan would be a permanent fix, but I can't say it's easy enough I would try it myself. There are few other quick fixes like oversized drain plug that self thread into existing hole but I have read some mixed reviews on its effectiveness. The helicoil or Time-Sert types of insert are also available, but it is probably about as easy (or hard) as the tap and die fix. I would try what @Mendel Leisk suggested first. It maybe that there are still enough threads, but they are just cross thread so making it not to tighten snug. But if you are going to try that, you would have to drain oil anyway. I would suggest to have the planB (either tap and die with M14 or use helicoil or Time-Sert) ready when you do it.
    #45 Salamander_King, Feb 12, 2020
  6. Taxi/Limo
    524
    107
    Where do you get a M12x1.25 Tap?
  7. Georgina Rudkus
    3,343
    2,337
    Taylors, SC
  8. ASRDogman
    ASRDogman Senior Member
    7,114
    3,713
    Definitly water in that oil!
    And if he had used the CORRECT filter wrench, it would have come off!
    That tool does NOT put the clip out of the way.
    And then only hand tight???? It should be tighter that that!
    LOT'S of goop on that drain pain!
    Kind of a waste since the head gasket is blown....
  9. Mendel Leisk
    40,459
    Oh c'mon, you're normally a very sensible guy: that clip does squat, lol.
    Notice how he mentions two of the underpanel bolts were rust lumps and he snapped their heads off? It's a very good idea to back out all those small bolts on the underside, put a drop of oil or a swipe of anti-seize on them. Toyota's rust protection on bolts is non-existent.
    Yeah I noticed that: coolant??
    Georgina Rudkus likes this.
  10. Georgina Rudkus
    3,343
    2,337
    Taylors, SC
    That's because of voluntary RoHS rules that avoid hexa-chromium and cadmium. In older cars, plating containing those metals on bolts made them much more rust resistant. Now, almost all bolts are plated with zinc. When the effect of anodic zinc is gone, the bolts easily rust.
    Rebound and Mendel Leisk like this.
  11. Mendel Leisk
    40,459
    I painted everything I could reach with boiled linseed oil, and all those little bolts, especially down low, basically drip edges, I oil drench the threads.
  12. Taxi/Limo
    524
    107
    You left your response blank
  13. Mendel Leisk
    40,459
    You probably need to turn off an ad blocker; it's an Amazon link. Bit of a pain with this site
  14. ASRDogman
    7,114
    3,713
    The clip DOES do something on my oil filter housing.
    It snaps in between blanks on the housing and seemly would keep it from
    backing out.
    Without the clip, hand tight would be extremely risky of allowing the housing to back off.
    But, as always, "results may very".
    Coolant/water in oil. It's what causes the milky color when mixed with oil.
  15. Mendel Leisk
    40,459
    Yup. :sneaky:
  16. Georgina Rudkus
    3,343
    2,337
    Taylors, SC
    A less expensive alternative.
  17. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    I think you get what you pay for.
  18. Georgina Rudkus
    3,343
    2,337
    Taylors, SC
    Sometimes more.
    Other times; LESS.
    Anyone seen the laser cap that grows hair?
    How many do you want?
  19. Mendel Leisk
    40,459
    There's a CBC Radio show called "The Age of Persuasion". One episode, they were describing a start-up company with lacklustre product sales: they doubled the price, and stuff started flying off the shelves. (y)
  20. Salamander_King
    11,004
    8,925
    New England
    Veblen effect at work! We see that all the times.
