new 08 prius owner
Discussion in 'Gen 2 Prius Main Forum' started by richard203, Feb 21, 2020.
  1. richard203
    richard203 Member
    205
    45
    SF
    hi i was looking on this forum for awhile since im hunting for a prius and just got a 08 prius with a package 2. i just researched and package 2 doesnt come with foglight but mines came with the foglight. i did not check if the headlight is hid or not i will check tomorrow morning. thats the question im wondering. mybe i should carfax the car and see if it got into any accident.
    Data Daedalus likes this.
  2. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Congratulations on your 2008 Prius Hybrid. I have one of those too! A UK Spec Tspirit with all the extras available to the UK, including leather
    iPhone 6s +
    Georgejaunty18 likes this.
  3. richard203
    richard203 Member
    205
    45
    SF
    thanks, i'll be modding the prius soon after i done with the maintince on the prius.
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I hope they are appearance/handling mods, but if you mean engine performance mods:
    The atkinson cycle engine has a compression ratio of about 8:1 and an expansion ratio of 13:1, so exhaust gases are not still expanding in the exhaust as they would be in an otto cycle engine. A loud exhaust is louder, but not more powerful.
    The atkinson cycle engine holds the intake valve open during the first third of the compressions stroke, so intake air pumps back into the intake manifold. So it is never 'cold air' no matter what you do. If you make it a 'shorty' intake you can spew fuel/air mixture into the atmosphere, both polluting and altering the mixture for the engine, throwing codes. So loud intake is just loud, not more powerful.
    (BTW, it panics some new owners that they can see fluid in the intake, that is from the f/a mixture pumped back out and is 'normal' for an atkinson cycle engine)
    Atkinson cycle - Wikipedia
    Holding the intake valve open is going to make nitrous pretty useless and hard to tune, but both turbocharging and supercharging are 'effective' but the computers will mostly use the extra power to charge the battery, not speed you down the road. Finding space under the hood is a challenge, but the power is real. (You will not find kits, all the fabricating will be by you)
    Not trying to be disapproving, just trying to save you cash on mods that won't make power, just noise.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,136
    Tampa, FL
    Go to Welcome to Toyota Owners and click on "Join." Once you enter your VIN, you'll know everything about your car that Toyota knows, including any service done by a Toyota dealer. It won't tell you about accidents although, if it got body work at Toyota that would be there, I assume.
    Big +1 to @JimboPalmer's advice. (y)
    dig4dirt and SFO like this.
  6. ydpplqbd
    ydpplqbd Active Member
    551
    253
    Welcome!!!!
    You will have fun learning about your Gen2's idiosnycracies.
  7. richard203
    richard203 Member
    205
    45
    SF
    so i did a carfax and went to my local toyota to get the service list. the car got an front end accident mybe thats why one of the headlight looks new and the other one is not. for the foglight i guess the owner installed himself. 1 owner and toyota service so most of the time is only oil change and tire rotation did not do any major service yet. after i drive a bit the hybrid light came on so im planning to get greenbean battery since its life time. any good stuff about this company? about to make an appointment tomororw with them to install it.
  8. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Check all available options!
    Good Luck!
  9. dolj
    dolj Senior Member
    8,184
    4,167
    Wellington, New Zealand
    Not much, but plenty of bad experiences.
    Do not install a "rebuilt" "remanufactured" or "re" anything HV battery. Only install a completely brand new battery, preferably OEM. newpriusbatteries.com does a completely new module kit for DIY install for $1600, which is a pretty good deal.
    jerrymildred and dig4dirt like this.
  10. George W
    George W Senior Member
    911
    514
    San Antonio
    for $149 more, go with newpriusbatteries, and get brand new cells. I did, and very happy with them. Cyclindrical cells allow for better airflow, and quicker response to temperature swings. Nothing against GB, but if you are spending that much for a replacement, just get NEW.
    jerrymildred and Raytheeagle like this.
  11. richard203
    richard203 Member
    205
    45
    SF
    i guess im too late, i got the green bean battery already. my friend have them and he say he dont have any problem yet and say life time so i went with it too. after i got the battery i purchased dr.prius and did a battery life test and it say 91% is that good?
  12. jerrymildred
    11,517
    14,136
    Tampa, FL
    Not bad for a used battery, which is what you bought. Of course the accuracy of those tests is not something on which I'd bet my soul, but it's probably somewhere in the ballpark. Predicted remaining life of a battery is much like predicted miles in the gas tank. It all depends on how you drive, what the traffic is like, and what the weather's doing.
  13. richard203
    richard203 Member
    205
    45
    SF
    i have a question on the mfd display its only show current mpg can i change to avg mpg?
  14. dolj
    dolj Senior Member
    8,184
    4,167
    I presume you're referring to the Energy Monitor screen. That screen shows the MPG as it happens. If you switch to the Consumption screen (press the Consumption button, bottom left), the one with the bar graph that shows the average consumption since it was last reset (or on a 2004-2005, since the last time the tank was refilled).
  15. richard203
    richard203 Member
    205
    45
    SF
    thanks got it.
  16. richard203
    richard203 Member
    205
    45
    SF
    i have a question do the prius have auto headlight on? my prius headlight always on, if so wheres the sensor at mybe the owner covered the sensor and the computer think its night time thats its always on
  17. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    They automatically come one when you start the car, they automatically got out just after you shut off the car.*
    https://www.toyota.com/t3Portal/document/om-s/OM47613U/pdf/OM47613U.pdf
    The default delay is 60 seconds but the dealer^ can change this to 30 or 90 seconds or disable the delay. I parked in a garage at night, so disabled the delay. If it was a long walk to the house you might want 90 seconds.
    * If you never open the driver's side door after you hit Power, they never turn off. That will run down the battery quickly.
    ^ or you if you have an OBDII programmer
    #17 JimboPalmer, Feb 24, 2020
  18. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,150
    1,683
    Iowa
    Uh, am I missing something....
    The lights will automatically go on and off if you leave the lights ON. If you have them turned off, they do not go on until you turn the switch on...well...at least for the '08. The '06 is the same, isn't it?
    SFO likes this.
  19. dolj
    dolj Senior Member
    8,184
    4,167
    That is how mine work too.
    But Jimbo is saying there was an option for Auto headlights, which I never heard of in a Gen 2. Fairly sure it was never offered as an option in Australia/New Zealand.
  20. cthindi
    cthindi Member
    177
    85
    Connecticut
    If you get out of the car with headlights on and then lock the car, headlights go off. Atleast they do in my 2005.
    They would come on when you re-enter and turn the car on.
    It is kind of Auto headlights.
