aftermarket Self-Driving (steering too!) $1000 system from Comma.ai
Discussion in 'Prime Main Forum (2017-2022)' started by The Big Sleaze, Feb 22, 2020.
  1. The Big Sleaze
    289
    63
    'frisco
    2020 Prius
    Two Eco
    Feb 2020 paper issue of Car and Driver mag has story on Comma.ai aftermarket Self Driving system for "most Toyota and Honda" cars, which I'll assume includes Primes with elec steering and other elec braking features.
    Says its about equal, more or less, to Cadillac and Tesla factory systems.
    I'm about 85% happy with Prime's radar Cruise Control, and IMO its the biggest improvement in cars since automatic transmission. To me, a decent Self Driving (steering added basically) would be perfect for my daily long freeway commute, some in very slow traffic. Any other aftermarket add-on Self Driving systems?
    Anyone with exp with Comma? I tend to be a late, rather than "early adopter", but this sounds like just what my Prime and my commute is missing. Only got 4K on the car so far, maybe I'll wait for a few months or when I'm at 26K with only 10K full electronics Warranty left, to hedge my bets.
    2020 Prime not yet included, but 2019 is, so I guess I'll need to wait because I'm not up for "manually adding support" (whatever that means) with its Open Source software.
    comma two devkit | comma.ai shop Only things I don't like is screen wants to mount in center of windshield (Caddy and Tesla mount on dash), and I rather not the "face monitoring" feature. Maybe point that camera at a bug-eye face mask, lol.
    C & D story says Toyota says "will void warranty", but I'm not too worried for few reasons. Mainly, IIRC from Business Law 101, sellers need an honest to goodness Cause and Effect reason to Void Warranty in most cases, and/or can only Void Warranty to the extent bringing it back to specs is not covered. Like maybe Toyota could charge for resetting System Software to factory, but unless they can say using Comma actually burned circuits Warranty would be upheld in court. Then again, putting car under completely new system hardly trivial, and Toyota would probably send their "A-team" to any court test case.
  2. schja01
    schja01 Senior Member
    1,814
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    Go for it. Report back.
    pghyndman likes this.
  3. fuzzy1
    10,335
    See this thread: My Prius Prime Drives Itself | PriusChat
    Though I still take serious issue with any true "self driving" claims at this time. The design, testing, and certification of systems reliable enough for general consumer use just aren't here yet. Misuse of existing driver assist features has already led to self fatalities. If or when such misuse leads to collateral fatalities, on systems not already demonstrated or certified as safer then average human drivers (about 1 death per 100,000,000 vehicle miles traveled), the misusers should face full liability, potentially even vehicular homicide charges.
    #3 fuzzy1, Feb 22, 2020
    Hicksite likes this.
  4. The Big Sleaze
    289
    63
    'frisco
    2020 Prius
    Two Eco
    Thx for link. Consensus seems to be "works great" (for intended use, staying in one lane on freeway). Toyota's "lane keeper assist" works, but will want to bounce you from white line to white line.
    When you add in less fatalities because these cool features make it more attractive to buy new cars in the first place (which are safer for other drivers for all sorts of reasons) I'm sure that even with lots of misuse we still come out way ahead, and any deaths from early adopters helping makers "figure it out" wont even be a blip on the radar. Five years ago I was convinced all this "self driving" was simply not gonna happen anytime soon, because the public would force politicians freak out for all sorts of reasons. Looks like I might be wrong.
    I'm sure old skool 1960s Cruise Control caused its share, and still does. Heck, things like power steering, A/T etc that enable the elderly to keep driving huge cars is an issue, as reflected in higher insurance rates.
    I plan on getting this after 2020 Prius becomes "supported" and a few others test it.
    Data Daedalus likes this.
  5. fuzzy1
    10,335
    I don't share that confidence. You must compare against equivalent new cars without those assist features too, or with such features turned off.
    Full
    self-driving is a really tough analytical and computational problem, far beyond what we are accustomed to seeing in other applications.
  6. Gokhan
    Gokhan Senior Member
    5,639
    2,225
    Paramount CA
    This system has only two cameras.
    Tesla has eight cameras (covering a complete 360° around the car), one forward-facing radar, and twelve sonars (also covering a complete 360°) according to Wikipedia. The computing platform is also far more sophisticated.
  7. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    2020 Prime is supported. I'm using the first gen on my limited and it works great. The comma 2 has an IR camera so it can see you in the dark and a better cooling fan.
  8. eskudo12791
    eskudo12791 Junior Member
    22
    Virginia Beach
    I thoroughly enjoy my comma setup. But IMO, its a stretch to compare it to Tesla. Comma is LKAS + ACC on steroids.
  9. Schrauger
    Schrauger Junior Member
    27
    I've got a 2020 Prime and a Comma 1, and it works really well. However, I'm running a slightly modified fork to give smoother steering. The 2019 and 2020 Primes have TSS-1 like the older 2018 and 2017, but they have an upgraded steering sensor. The better steering sensor is important to prevent ping-pong effects (where the car overcompensates back and forth due to poor precision or feedback delay).
    The main OpenPilot code doesn't take advantage of the upgraded steering sensor, but several forks do. Hopefully, Comma.ai will accept the pull request to incorporate the new sensor so 2019 and 2020 prime owners won't have to run a fork to get smoother steering.
  10. schja01
    1,814
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    What's a "fork" in this context?
  11. fuzzy1
    10,335
    Forked or diverging software paths?
  12. Schrauger
    27
    A "fork" is terminology used in some source control software, like Git. OpenPilot is open source software hosted on GitHub, so anyone can easily copy the code and publish their own version with minor or major tweaks. The code has diverged from the original, so it has become a fork.
    GitHub, and the underlying source control software git, makes it easy to merge new changes back in, so it's pretty easy to make a fork with your specific code changes, yet always keep it updated with the original software so you continue to get updates and improvements.
  13. schja01
    1,814
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    My mind was thinking hardware. Tnx.
  14. Blue-Adept
    Blue-Adept Active Member
    293
    179
    Grand Rapids, Michigan
    2018 Prius Prime
    I have the Comma 2 on my 2018 Prius Prime Advanced and it gives me 98% of what I want. New option called the Smart DSU will be released soon to make it even more desirable.
    Took me 20 minutes to install.
    Very Little Ping Ponging between the lines.
    #14 Blue-Adept, Feb 27, 2020
  15. slsmag
    slsmag Junior Member
    NE Ohio
    2018 Prius Prime
    2018 Prius Prime Premium with comma 2 & Openpilot
  16. The Big Sleaze
    289
    63
    'frisco
    2020 Prius
    Two Eco
    Comma 3 is now starting at $1999! And they want $500 for an extra TB of storage!
    Oh well, I was HOPING the $1000 Comma 1 would be like $299 by now.comma three devkit | comma shop
    I guess its going in the other direction. Does Comma 3 do like point to point in traffic including stop signs and stop lights or something, or is it just somewhat better on highway without ping ponging or something. Seems like it STILL is rather obtrusive on the windshield.
  17. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    This thing is a game changer for people like me who drive 150 miles or more a day. If buying a Prius, note that 2021 and newer will be the best for OP, 2019 to 2020 will need an SDSU for optimal experience, 2018 and older will require SDSU and zss for the best experience.
  18. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
    It doesn't yet do lights and stop signs, but will soon. It doesn't obstruct view of the road because it's mounted high. Works great in traffic, in cities, with or without lane lines. It just makes driving chill.
  19. fuzzy1
    10,335
    Don't let your expectations get too far ahead of the actual current technology.
