Multi-display/Cable Problem, Error Code B1248 - HELP!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gordonsta, Jul 24, 2009.
  1. gordonsta
    gordonsta Junior Member
    Port Charlotte, Florida
    2015 Prius v wagon
    Short Problem Description:
    Today the Multi-display in my 2005 Prius went haywire. :( I have a couple of after market plug ins, but they have worked flawlessly since their installation over two years ago. I took it to the dealer and they came up with error Code B1248 - "AVC LAN Communication Impossible".
    Detailed background:
    Shortly after purchasing my 2005 Prius I added two aftermarket modules to the Multi-display. The first is the DICE iPod and the second is the Lockpick that unblocks video and audio inputs. The car has performed flawlessly since their install a number of years ago. Today I drove to a destination and parked the car for about 30 minutes. When I started the car I noticed that the Multi-display was not acting properly. I took it to the dealer and they reported that the initial tests showed an error code of B1248. They want $380 to tear into the dash and troubleshoot further:eek:. I picked up the car and brought it home. I removed the Lockpick plug-in but the symptoms were the same.
    Last thoughts:
    Wiring harnesses rarely just fail. Tomorrow I'm going to dig into the DICE iPod plug-in to see if possibly something there has worked loose. I would appreciate any other thoughts about what might have happened.
  2. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    There are only two connections between the Gateway ECU and the MFD that can cause this problem, or the MFD is has no power. I don't know how these mods are installed. If you need the service manual pages, if you give me your email, I can email you the section.
  3. dogfriend
    7,512
    1,189
    Carmichael, CA
    I think its likely that something in the Dice failed. Aftermarket electronics are rarely built to the same standards as OEM. However, there is a documented issue with the MultiDisplay in some 2004 and 2005 cars due to a design error.
    Prius MFD
  4. gordonsta
    2015 Prius v wagon
    Woo-hoo!!! Success!!! This morning I opened up the dash, unplugged the DICE iPod plug-in, powered on the car and the MFD started working properly. :whoo:
    Then I decided to go for broke. I powered down the car, replugged the DICE and powered on the car. Everything was still working. After powering down again, I unplugged the DICE, squirted a bit WD-40 on the contacts before reassembling everything and buttoning the dash back up. I tested it once again and everything was still good.:D
    My last act was to reinstall the Lockpick plug-in. Everything is still working fine. Thank God for small miracles:)
  5. Ibrahim82
    Ibrahim82 New Member
    Dubai
    Kindly email me....i am having b1248 problem...ur help will be appreciated
  6. Ibrahim82
    Dubai
  7. Ibrahim82
    Dubai
  8. Marty2go
    Marty2go Junior Member
    Ohio
    Four Touring
  9. Marty2go
    Ohio
    Four Touring
    I had this code B1248 show up when I stole the MFD for another car so there wasn't any MFD in the car. NObrainer.
