Does the gen 3 have a traction batttery air filter?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Mar 3, 2020.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    Hello All
    I pulled off the vent cover on the passenger back side of my gen 3 but I did not see a filter attached to the vent
    Does the gen 3 have one and if so how do I check it?
    Thanks
  2. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    nope, but you can get one from the dealer /
  3. Taxi/Limo
    524
    107
    That's disturbing
    Why no filter?
    Alot of dirty air goes in there
    Can you get one somewhere else?
    Thanks
  4. bisco
    51,884
    elearnaid.com
    i think toyota started adding them in the refresh. why not sooner? no idea, toyota is inscrutable
  5. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    negative, my refresh didn't have a filter. filter would obstruct intake efficiency so that's why a code will be thrown to clean.
  6. Mendel Leisk
    41,389
    Yeah I think the later 3rd gen years added a filter.
    Still, I would not count on it; have a look for yourself, clean everything, including the fan, so you've got some idea how fast the dust/lint builds up.
    FWIW I put a piece of window screen mesh on the back side of the inlet grill, and made a point to check it everything, a couple of times so far. With our very low miles, and the near-pristine appearance of that screen so far, not sure if I'll bother doing a full clean for a long time now.
    But it's good get a "baseline", so you know.
    mikey_t and Grit like this.
  7. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Nice technique. My diy filter is from a mosquito repair kit. Has Velcro snap to secure the net around the intake lip.
  8. Taxi/Limo
    524
    107
    Are there any instruction videos on how to get at the fan
    Thanks
  9. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    @NutzAboutBolts is a member here and has tons of great video walkthroughs for most prius maintenance.
  10. Mendel Leisk
    41,389
    Yeah good video. One comment: you can avoid pulling off the rear seat. There's just one bolt you need to access behind the seat, in vicinity of the air inlet grill. If you push apart the seat back and bottom, you can reach through with a 12 mm socket on a 6"~ extension. Be careful not to drop the bolt.
    mikey_t likes this.
  11. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    There’s no filter because it isn’t necessary unless you often drive with pets in your car.
    The engine has a filter because dirt is very bad inside the crankcase. The cabin has one as a comfort feature to make fresh cabin air a little cleaner — cars had no such filters for decades.
    The fan which cools the battery pack is pretty big and dirt won’t effect it, only lots of hair.
    Grit likes this.
  12. Taxi/Limo
    524
    107
    Seems like the compete process Thanks Nutz
