BLUE painters tape shenanigans
Discussion in 'Gen 4 Prius Main Forum' started by BlackT0P, Mar 4, 2020.
  1. BlackT0P
    BlackT0P New Member
    North California
    Four Touring
    Me and the wife are taking a trip back home to see family this week. We recently got our Prius back from a $10K+ body shop repair bill covered by AAA and don’t wanna ruin the front of the car so soon after getting it back. So I did what any car guy would do.......
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Maybe you could get it shrink-wrapped (film). They might have it in blue!!!
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    FYI, the glue on painters tape causes corrosion to metal, if left on for any length of time, not sure what it does to paintwork over time if left on.
    alanclarkeau likes this.
  4. davecook89t
    davecook89t Senior Member
    1,076
    812
    Washington State, Florida
    Four Touring
    Nice job, you even cut out holes for the parking sensors. How many hours did it take to do all that?;)
  5. ETC(SS)
    7,060
    I was wondering about that myself.
    BT is used primarily to keep things from getting paint on them, and it's meant for short term use on surfaces that have not just been freshly painted.
    I would probably lean away from using it on a freshly painted nose.....
    Good Luck!
    kithmo and davecook89t like this.
  6. frodoz737
    frodoz737 Top Wrench
    4,646
    2,486
    33
  7. alanclarkeau
    7,045
    7,592
    I think it's got something like 20 days before it needs removing. But - as mentioned above, depends on the substrate it's applied to, which in a car should be fairly good.
  8. Lightning Racer
    Lightning Racer Active Member
    239
    321
    Anchorage, Alaska
    I'll warn against it. I had a big, thick chip of pant come off a close to freshly painted front bumper cover on my (former) Prius. I had used painters tape to protect the paint when I was restoring the headlights (wet sanding and polishing). The paint on plastic doesn't stick as well as the paint on metal, even with proper prep, and you don't how well they prepared the paint (perfectly clean, used adhesion promoter?).
    ETC(SS), kithmo and Raytheeagle like this.
