Blown Head gasket rebuild....@297k
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 8, 2017.
  1. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    Will sure check back with dealership on FIPG.
    im attaching some head and block pictures, there was plenty of fluid invasion in motor. I dont know how to evaluate what i see in pictures. Does it look fully destroyed? Or can it be easily cleaned restored?
    The head gasket was fully covered with water and leak was very very significant.
    C50AF7E4-63CC-4CCA-93F6-A0B1F9885C3C.jpeg A5029922-4D5E-489D-84A0-7EED83700767.jpeg 35C19688-02C2-4A95-A25D-A3239B5EE134.jpeg 9DDE1FE8-5949-44B3-898F-3DE67953E15C.jpeg 41A3F7F4-916D-4D3A-89C5-D376B74FDE03.jpeg 96E931BD-F9E5-478C-83FF-54EC3CD5EAE6.jpeg 0595BED6-167C-4FDA-A3F7-F2FCE8C15E6B.jpeg 6C735455-FF30-4B53-AB91-325506375A84.jpeg A227AA56-6828-460D-AECA-66AC4E6F914E.jpeg 82E9F98C-B3EB-4CFA-B823-AC322E49AB39.jpeg 49E930FF-5352-43DB-AA04-2B5099A38B78.jpeg 775103B6-337C-494E-A241-408793F54FA4.jpeg 39AF5F61-A028-4A62-A66B-0CE712FD2D95.jpeg 7E537C25-97F3-4C04-8189-895D38AEDC1D.jpeg 0484F4E5-A5B3-4A07-A4A3-01129A906D87.jpeg 2D7F9364-F2A6-42F7-88A2-337AE5B3B363.jpeg E5C67A0E-CF57-4613-AA4E-407D48899042.jpeg 7962BA5D-6784-4DCB-9397-1895BCEC5D36.jpeg 376D60C6-DEF3-4523-BB69-A3023E3D38A3.jpeg
  2. Mendel Leisk
    40,472
    That's pretty nasty. :(
    My first thought is machine shop for the head, but I suspect that's not in the cards?
    Definitely gunk in the oil.
    #1 cylinder piston definitely cleaner than the rest.
    I wonder if you crank the engine by hand if the pistons all come up to the same Top Dead Center. Good to check, to verify you don't have a bent piston arm.
    mikey_t likes this.
  3. Mendel Leisk
    40,472
    Is the intake side on the left? Some evidence of gasket sealer (flagged)? The valves look pretty bad, and no two cylinders the same.
  4. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    I never used gasket sealer. I have owned this since 70k miles and never used gasket sealer. At70k miles i dnt think previous owner wud have had gasket leak issues
  5. Mendel Leisk
    40,472
    Yeah I though the same. Come to think of it, the coolant is pink... :oops:
    Umar Ali likes this.
  6. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Need to decide budget. How much are you willing to put into this.
    1 Need to carefully clean head and block
    2 need to check for warpage on both.
    Budget and straightness will decide if it is salvageable.
    Can get set of valves for $75 have to check with machine shop how much they will charge for seat cutting and head servicing. Mind you can get head altogether for under $500.
    I just did this not too long ago on mine pm me if you wanna know what I would have done different.
  7. Raphael Muscarelle
    661
    222
    Yup coolant is pink so why the white.
  8. Raphael Muscarelle
    661
    222
    Without seeing all the pistons down so I can see the cylinder walls and without checking for warpage. Looks like you should check more.
    I would at least see of all the pistons are even at there top of stroke. Now you could use a disk gauge to check on u. Need to see if those connecting rods are bent.
  9. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    How often did you change the oil in this engine? That valvetrain looks nasty.
    If there was significant coolant intrusion, you may have bearing wear and possibly bent rods from combustion of the coolant. How long was the engine driven with a blown head gasket?
    I think a used engine is the best option here...or at least a new short block with machine shop inspection of the existing cylinder head.
  10. Tim Jones
    Tim Jones Senior Member
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    Did I Make A Mistake Buying A 2010 Toyota Prius? | Torque News
  11. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    I have always religiously used mobil 1 every 10k or lower. Never skipped on oil changes or went over 10k.
    I cranked it to check all cylinders are coming up to the top at same height i didnt notice any difference.
    Used couple of cans of brake cleaner to blow off that carbon on top and had some success, dnt wanna touch the surface with any scrubbing material.
    72361926-CF66-435B-94CF-432D6477DCCF.jpeg EEA93985-30F7-4661-BDAD-9EDDEA857C9B.jpeg 276B5A2D-B7A5-43CE-A556-32C8FE5F9E30.jpeg 9F5022A3-371E-4FF7-A78F-5561960FBBF4.jpeg D184C2C8-EE47-4B1C-8587-8156CDDCCFD3.jpeg
  12. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    If i fix head gasket and clean egr cooler , im keeping it for another 100k and then get rid of it. Only reason keeping for another 100k more is because after putting so much effort and time i dnt wanna just throw it away.
    NEVER BUYING ANY HYBRID AGAIN EVER
  13. Mendel Leisk
    40,472
    Don't conflate engine woes and hybrid.
    Yeah it might be, since the 3rd gen EGR was introduced at least in part to improve mpg? Ditto for the low-friction oil rings, light-weight pistons, or whatever it is that's causing them to coke up.
    But I don't see it as direct correlation, that hybrids kill engines.
    mikey_t likes this.
  14. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    Hybrid for the reason of costly traction battery, cost to replace is awful and again amount of time n effort to refurbish them is still not worth it in my opinion. I have been clearing hybrid battery code and running it like that for over 1k miles now. Refurbishing hybris battery is next project and im not looking foraward to it
    Tim Jones and Mendel Leisk like this.
  15. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    That's the only reason I keep mine. I haven't done the motor but almost everything else.
    What is the condition of your traction battery?
  16. Raphael Muscarelle
    661
    222
    U didn't worry about getting stuff in rings
  17. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    I tried all that recharging stuff.... I bought a new battery for $1600 and never thought about it again.
  18. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    pardon my ignorance but what is that? lol
    should i be worried about any rings? thhis is just brake parts cleaner, cant it be flushed with engine oil? since i plan to put oil after button up and drive for abt 20 miles and flush it.
    edit: i googled piston rings, that carbon is sitting on top of cylinder anyways, it wud had gone into piston rings if i didnt clean it anyways?
    or is brake cleaner death for that material?
  19. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    im not shelling $1600 for traction battery, no way. i rather sell it to junkyard than putting that much money in it. At 231k miles it not worth it to me spending $1600
  20. Mendel Leisk
    40,472
    I think you're doing ok, having shop towels stuffed in the oil/coolant passageways, and cleaning the pistons. Just don't go nuts with liquids I guess. And use some form of compressed air to blow particles away. Even a shop vac on blow.
    Brass bristle brush would be good I think.
    Tim Jones and Umar Ali like this.
