Averaging 35mpg
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wackofamily, Mar 8, 2020.
  1. wackofamily
    wackofamily New Member
    sutherlin
    I have 2012 Pruis 4 with about 140k, for last 2 months I have been getting about 35mpg from 50mpg.
    I have
    Clean Erg pipe
    Clean mass air flow sensor
    Replaced the air filter
    Replace the spark plugs.
    Replace the 12 volt battery
    The vehicle spends most of it on the freeway commuting to work.
    I have no check engine errors or battery errors
    52,024
    Just the egr pipe?
    Tires pressure?
    Oil level?
    pjksr02 and Mendel Leisk like this.
  3. Mendel Leisk
    41,558
    Exactly.
    pjksr02 likes this.
  4. working1
    working1 Active Member
    121
    112
    When was the last time the brake caliper pins have been inspected and re-lubricated?
  5. wackofamily
    sutherlin
    Just the egr pipe.
    Tire pressure is at 40 psi
    Oil level is perfect and was change about 4k ago
  6. wackofamily
    sutherlin
    They were inspected during the last oil change about 4k ago.
  7. Mendel Leisk
    41,558
    Is 140k miles or kms? Either way, full EGR and intake clean is always a good idea.
  8. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    How did the pipe look like the first time before cleaning? And how many miles was it?
    pjksr02 likes this.
  9. wackofamily
    sutherlin
    Pipe look a little dirty, but not that bad.
  10. bisco
    52,024
    good news
  11. wackofamily
    sutherlin
    I clean the EGR valve and cooler. The EGR was a little stiff but after good cleaning it was alot better. But I am still averaging 35 Mpg.
    No codes
    I ran Dr Prius, nothing stands out.
    Only thing I have found from Car scanning app.
    Under current drive cycle for emission test it fails for
    Catalyst
    Evaporative System
    Oxygen Sensor
    Oxygen Sensor Heater
    EGR System
    But it passes over all. FullDiagnostic_2020-03-06_05-28-10.jpeg LifeTest_2020-03-07_05-33-21.jpeg Screenshot_20200319-162916.jpeg
  12. wackofamily
    sutherlin
    Also I got new tires 205/65/R15. Not sure that is also causing the issue
  13. bisco
    52,024
    wow, thats a lot of issues for a '12 with 140k. have you owned it since new?
  14. bisco
    52,024
    have you checked all the wheels to make sure nothing is binding?
  15. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    I will just say that 50 ==> 35 MPG is a lot of energy lost. It must be going somewhere. Either out the tailpipe as unburned fuel, or maybe as a previous poster suggested, as a dragging brake. A pyrometer to measure the brake rotor temperatures after a long drive might indicate that, or simply jacking the car up and seeing how freely the wheels spin.
    Gas smell at tailpipe? Anything surprisingly hot? Anything changed that would dramatically affect the aerodynamics?
    My 2012 Prius v gets a little over 40 mpg (always has, even the PO), but we don't drive it like it's a Prius, and the v is known to get lower mpg due to the increased size and weight.
    Not sure what to make of the Dr. Prius output there. It seems to say the O2 sensor is both good and bad. A bad sensor would probably cause the engine to run rich, sending unburned fuel into the cat and out the tailpipe.
    Robert Holt likes this.
  16. wackofamily
    sutherlin
    I am second owner, I bought with 40k
  17. bisco
    52,024
    thats close enough. i would get tech stream and pursue any error codes
  18. Mendel Leisk
    41,558
    Have you removed and cleaned the intake manifold? Pay special attention to the EGR passages. Clean the intake ports while you're at it.
  19. wackofamily
    sutherlin
  20. wackofamily
    sutherlin
    I think I fixed the issue. Been on one test run and got 47mpg
    Thanks everyone for the advice and help
    ASRDogman and bisco like this.
