Brake, ABS, Slip warnings are on when starting the car after parking continuously for 5 days
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sajith Dulanjaya, Apr 7, 2020.
  1. Sajith Dulanjaya
    Sajith Dulanjaya New Member
    Colombo, Sri Lanka
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Check your 12v battery
  3. pjksr02
    pjksr02 Active Member
    532
    227
    Connecticut
    Then read the codes, if they return. Use a code reader, or you can jumper TC and CG, and count the flashes of each indicator light.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    This. Before you do anything else.
    And if it is the original from 2012, no need to "check" it, just get a new one.
    dig4dirt, pjksr02 and ASRDogman like this.
  5. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
  6. Mendel Leisk
    41,347
    That needs a little more explanation?
  7. ChapmanF
    18,100
    It has a strong whiff of "sounds like a reference to something that has already been posted about dozens of times on this forum and would make a useful search phrase".
    pjksr02 likes this.
  8. Sajith Dulanjaya
    Colombo, Sri Lanka
    Yes. It's the original factory fitted one. Thanks for the opinion.
  9. sam spade 2
    7,035
    2,801
    2017 Prius c
    8 years is on the outside edge of the expected life range of a car battery.
    That is a fact, not an opinion.
