Battery dead, cannot jump start
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Nandeesh N, Apr 26, 2020.
  1. Nandeesh N
    Nandeesh N New Member
    South Brunswick NJ
    Hi Folks -
    I am a happy owner of a 2014 Prius since the past 2.5 yrs (bought it certified-used), and I recently noticed that my car battery is dead. I don't think I had left any lights on when I parked the car in my garage, and I noticed that the battery died (pressing the start button doesn't start, cannot unlock trunk, no lights inside car...) after about 1 week of the car sitting unused in my garage.
    Yesterday, I had a towing service guy come in to jump start my car, and that didn't work either. He had the jump starter connected but I wasn't able to start the car, nor unlock the trunk. The key fob battery is fine, I can see the red light blink whenever I press any button on the key fob.
    I spent a lot of time yesterday researching what could've gone wrong - my guess is that the towing guy didn't connect the jump starter correctly, or didn't leave the jump starter connected long enough (it was connect for about 3-5 mins) or there's some other serious issue with the car.
    Do you have any suggestions as to what I should do next? Is it a good idea to try to jump start again? I am trying to avoid having to tow the car to the toyota service center unless it's really needed.
    Thanks in advance!
  2. JC91006
    JC91006 Senior Member
    16,744
    8,551
    Yes the towing guy probably didn't have a good connection at the jump points. Most likely a dead battery that's 6 years old, it's a little early for it's death, but it happens.
    Good time to get a new one
    Nandeesh N likes this.
  3. ETC(SS)
    7,082
    Your original 12v battery is probably defective.
    The tow truck person may not have connected the jumper cables incorrectly, he or she might simply not have used a good ground when trying to restart your car.
    1. You're going to want to get a replacement battery and put it in the car. If you cannot do this yourself then you can at least manually release the rear hatch for the next jump attempt:
    Fortunately.....the good folks over at @NutzAboutBolts made a video showing you how....
    2. You will want to avoid taking your car to the dealership for this problem.
    Good Luck!
  4. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Might be worth thinking about getting a jump starter of your own because it might come in handy later either for yourself or to become a Good Samaritan for someone else even if it does not solve your immediate problem and you have to buy a new battery now anyway. I bought this one, although I haven't had occasion to use it yet:
    Sorry: I don't know why the link I posted previously doesn't work, but it's Amazon item B07DWSYYZR
  5. bisco
    51,590
    try disconnecting the 12v negative, then jumping it
  6. Nandeesh N
    South Brunswick NJ
    Thanks for the your responses folks. I am going to try to jump start again, and this time I'll make sure to confirm that the jump start is done correctly. Once I get the car to start, I'll go and get the battery replaced.
