Pipe hanging off back of car
Discussion in 'Prius c Technical Discussion' started by Mike Massa, Apr 5, 2020.
  1. Mike Massa
    Mike Massa New Member
    Richmond, VA
    new to forums. I hope this is the right place to
    Post this. I was rotating the tires on my 13 Prius C today and noticed a hose that has the end broken off in some sort of cylinder under the back of my car. It looks like a vapor hose from the filler or something.
    Anyone know what the part is, and what parts/part numbers I need to fix it?
  2. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    I dug a bit.
    Cannot seem to find the separate piece, looks like they only sell the whole fuel filler and fuel tank as one part.
    I am just confused on what it goes in to.....like a box of some sorts.
    Any check engine lights?
    I see a dented section above in the spare tire well. Must have backed into something?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    OUCH. That sounds VERY expensive.
    Maybe it can be "glued" back together ......with the right type of glue ?
    dubit, Mendel Leisk and dig4dirt like this.
  4. Leadfoot J. McCoalroller
    8,071
    7,553
    Pennsylvania
    2018 Prius c
    Yeah that will be very pricey unless you get a secondhand one from the junkyard. I think that is the charcoal canister. Must have been caught in some underbrush.
    dig4dirt likes this.
  5. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
  6. Mendel Leisk
    41,334
    Yeah glue and reinforce with sort of sleeve if possible.
    You can't protect everything, but the Prius c underside is a bit of a design fail, also has some exposed high voltage cables IIRC.
  7. ChapmanF
    18,083
    Looks to me like that hose attaches to a nipple on the leak detection pump, and the nipple broke off, and is still in the end of the hose.
    I would investigate just replacing the pump (the $300 shown above is MSRP, the dealers that sell online will have discounts), unclamping the end of the hose to pull the old busted nipple stub out, sliding the hose onto the new pump, and putting the clamp back.
    The discounts look to be about 1/3 off, so $200-ish plus shipping, depending on the dealer.
  8. AlphaFox
    AlphaFox New Member
    East Longmeadow, MA
    2018 Prius c
    JB weld stick. its a putty like playdough you can form and then smoosh around the are to glue. you can even drill and tap it after, works great.
    Montgomery likes this.
  9. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    While you are at it, get a pair of jack stands. Don't work under the car without them, or your project could cost you your life.
    Dire message out of the way, I hope the rest of the repair goes smoothly!
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Any quality epoxy type product will fix that with no problem. Remove the broken piece from the hose, bond it back to where it broke off and let it cure. reattach the hose and all should be well.
    Or search for someone parting out a broken car...
  11. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,442
    2,412
    Taylors, SC
    The plastic housing is most likely marked with PA-6-6, 35 GF, which means that it is made of 35% fiber glass filled poly amide 6-6 (nylon).
    The brake will be very jagged which is a good thing. That increases the bonding surface area and the break makes a perfect "keyed" break.
    I's use slow setting JB Weld, which will likely make a permanent repair stronger than the material itself.
