Prius 2012 hybrid battery pack
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gotrock20, Jun 25, 2020.
  1. gotrock20
    gotrock20 Junior Member
    FL
    By looking at the pic, can someone tell me if this battery is dead?
    I know 9,10 is out
    2-8 is about to go out on me soon.
    Should I Replace all those cell or just buy a new battery ?
  2. Salamander_King
    Salamander_King Senior Member
    11,016
    8,947
    New England
    I don't have an answer to help you, but I reported the thread to be moved to an appropriate sub-forum. You are asking about your 2008 Gen2 Prius, aren't you? This is the Prius PRIME maintenance sub-forum. You will get better answers from the Gen2 maintenance sub-forum. Good luck.
    #2 Salamander_King, Jun 25, 2020
    jerrymildred likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Going just by the photo, I don't understand why you have concerns about the battery. The battery is under a slight discharge and you have less than a 0.2 volt difference between the highest and lowest block voltages. All the IR values are reasonable for the age of the battery.
    What do you mean by 9 and 10 are out? If you're basing that on the lower portion of the graphs, that graph is internal resistance. 9 and 10 are the best, not the worst. And even the 27 is totally normal.
    Has it thrown a code that you're concerned about?
