Coasting down a hill, lightly braking, then...
Discussion in 'Gen 4 Prius Main Forum' started by Preebee, Jul 13, 2020.
  1. Preebee
    Preebee Senior Member
    867
    769
    Midwest
    2023 Prius
    ... the engine starts up and then shuts back off. This has happened a couple times. I do believe both times the AC was on but I'm not 100% sure. The battery was never more than 60-70% charged both times. Kind of irritating when I'm enjoying the free recharge down a ramp and the motor turns on.
    Any ideas?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    Are you in "D"? If so, it's likely that the battery or inverter temperature sensor has instructed the ICE to run.
    Pulse07 and -Yousef- like this.
  3. Leadfoot J. McCoalroller
    7,834
    7,298
    Pennsylvania
    2018 Prius c
    The engine was probably not burning any fuel during this "run".
    Fair chance that what you are experiencing is the car trying to divert energy away from the battery because it is either too full or too hot for good long-term health.
    Free watts on the downslope are great, but there really can be too much of a good thing.
    AzusaPrius likes this.
  4. esfishdoc
    esfishdoc Junior Member
    26
    45
    ESVA
    The Gen 4 Prius does exactly what it is programed to do. I have a bit over 100K on my 2017 and every once in awhile I'll notice something that I haven't noticed before. It happens. It just is. What you describe sounds normal to me although I couldn't begin to tell you why.
  5. alanclarkeau
    7,045
    7,589
    There are sensors for the temperature for MG1, MG2, Inverter and Hybrid battery, as well as the battery intake air temperature.
    TOYOTA have advised:
    Harters and Mendel Leisk like this.
  6. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    A hill? Kansas? Aren't they called moguls???;)
    What is the ambient temperature at the time, and did the ICE run going UP the hill?
    I agree, probably temp related.
    Question about Prii hybrid: if the ICE is "running" going down a hill, is fuel being consumed? Going down a hill, my TDIs would "run", but weren't burning fuel, even if the drivetrain raised the RPMs of the engine.
  7. Mendel Leisk
    40,484
    I'd suspect if the engine is running it is burning gas, but a minor amount.
    I recall on vacation last summer, protracted round-town driving on a warm day, once in a while the engine wouldn't shut down in cases where it normally would. Chalked it up to maybe the hybrid battery getting too warm, something like that, and the computers intervening.
    alanclarkeau likes this.
  8. mancuz28
    mancuz28 New Member
    Western NY, USA
    2020 Prius
    LE AWD-e
    Yeah...this is kind of annoying, but I've come to accept "it does what it does". I live at the top of a ~1 mile hill...every time I leave I try to keep the engine off until I get to the bottom, by going into EV mode to get out of my driveway, then ride the brake gently on the way down. But every time it hits 20mph, even riding the brake, on the way down the hill it decides it's time to warm up the engine. Oh well.
  9. Leadfoot J. McCoalroller
    7,834
    7,298
    Pennsylvania
    2018 Prius c
    What you're describing is "deceleration fuel cut-off" which has been a feature of fuel injection systems for decades. The transmission can force the engine to spin. No fuel is being passed through the injectors, so the engine is just a drag on the drivetrain.
  10. Mendel Leisk
    40,484
    Yeah think you're right about the fuel cut-off. In the scenario I described car didn't have downhill momentum, was in fact stopped.
  11. Leadfoot J. McCoalroller
    7,834
    7,298
    Pennsylvania
    2018 Prius c
    It's been observed that a stationary Prius will spin the engine for a while without fuel to discharge the battery when the battery is both hot and at a high SOC.
  12. alanclarkeau
    7,045
    7,589
    That's programmed into it too - think of what would happen (yes, extreme case) if it got to, say 100mph, coasting - and then an uphill rise comes, and you need full throttle to keep up speed - on a COLD ENGINE. Disaster - it's like my dog stretches when he first wakes up in the morning - then he's ready for action.
    Trying to chase EV Mode is often fruitless - it often doesn't make any difference to your litres/100km - sometimes, but not always.
  13. Preebee
    867
    769
    Midwest
    2023 Prius
    Thanks for all the replies!
    Here's a little more info on when I've noticed it happening:
    I'm on the highway for 10 mins mildly pulsing and gliding and ranging from 70mph down to around 60mph. My battery power usually stays above 4 bars. I trigger the ICE to come on whenever I am approaching a "mogul" :) On occasion I get to exit on a nice long off-ramp. My speeds are higher than normal - 50ish - and I'm getting a good recharge. About halfway to the stoplight I will see the MPG gauge drop (I'm using the split screen MPG monitor because it's more accurate) as if the ICE starts. Then it will immediately shoot back up to "100" indicating the ICE is off.
    Whenever this happens the battery is nowhere near full. I don't think I've ever even charged the battery full since I've owned the car. The reason it's bothersome is because if seems like an unnecessary start and I attribute each ICE start with a little wear and tear on parts. Maybe I'm wrong. Once I shut my car off when the ICE was running and it sounded like it didn't power down smoothly. I always let the ICE self-shutoff before powering down now.
    Outside temps were not unusually hot when this occurs but I may have had climate control on. I would have been using the battery on the highway a lot between moguls so perhaps it's for cooling purposes, but then wouldn't the ICE run longer? It just kind of flashes on for a moment and then shuts back off. I can feel the ICE starting so I know it's not just a visual phenomenon.
    And yes, I am always in D.
  14. robsnyder20
    robsnyder20 Active Member
    375
    302
    SW Florida USA
    Preebee, the activity you are describing with your most recent above post sounds completely normal. I know its frustrating when Ice comes on when showing down it does it for two reasons, (avoids use of friction brakes) and #2 attempts to avoid the battery becoming overcharged and so running ICE burns some of the excess battery off. Mine will rarely go above 2 bars to max full FYI . Just figured I'd chime in and say the behavior is completely normal.
  15. pianewman
    264
    183
    2018 Prius
    ...and in summer heat, 95f +, ICE cycles very differently than in winter, probably to circulate necessary coolant...
  16. Henrik Helmers
    Henrik Helmers Active Member
    100
    148
    Norway
    2020 Prius PHV
    I do this too, and I think we're wrong. The Hybrid Synergy Drive is already running, and so the ICE should not mind joining in.
    It would have been nice if the system indicated what the ICE is doing though, to satisfy my curiosity.
  17. alanclarkeau
    7,045
    7,589
    Get this display up - it shows what's running and what direction power is running:
    jerrymildred, Raytheeagle and krmcg like this.
  18. Mendel Leisk
    40,484
    That display makes me nervous though: by the time I figure out what's happening I'm almost off the road or about to plow into someone. :eek:
    dig4dirt and Raytheeagle like this.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    In the RX you can have that in 3 displays:cool:.
    And all are different sizes:).
    At least they give you options to figure out which one is just right(y).
  20. alanclarkeau
    7,045
    7,589
    You can get a fair idea with the HUD, if that worries you.
