HV Battery Temp is abnormal? Causing red Triangle
Discussion in 'Gen 2 Prius Technical Discussion' started by Drake123, Jul 27, 2020.
Tags:
  1. Drake123
    Drake123 New Member
    Utah
    Hey everyone. I am trying to see if there is a problem with my fan or ducting causing the HV battery to overheat. It seems like the high temp is causing a P3000 code. Does anyone know what the temp is supposed to rest at? This was at an idle when it was around 85 degrees. Thanks in advance!
  2. Isaac Zachary
    Isaac Zachary Senior Member
    2,271
    1,118
    Was the car parked in the sun and for how long? Was the A/C on? For how long? Was the battery fan on full blast? Did driving it with the A/C on help make the fan noise go down?
    I'm no expert, but I think that in the right conditions those temperatures could be normal. But the code is concerning. Hopefully someone with more knowledge will chip in. If parked in direct sunlight your car and components could heat up much hotter than ambient temps. Then charging during idling will only heat up the battery even more, and the car won't be able to cool the battery yet because the car is full of hot air.
    The way the cooling system works is the A/C has to be on for a while and cool down the inside of the car. Then that cool air is drawn in and blown over the HV traction battery. No A/C, no battery cooling.
    On the other hand, if the air ducts and blower haven't ever been cleaned out since your car was new 13 year ago and you're getting hot battery codes, it's probably time to get it cleaned out.
  3. Isaac Zachary
    2,271
    1,118
  4. fotomoto
    fotomoto Senior Member
    5,628
    3,802
    So. Texas
    I've seen those temps in south Texas too. I think your battery is just demonstrating another sign of getting older and weaker (keep an eye on blocks 9&11). Temperature extremes (summer and winter) bring on a rash of failures posted here.
    GOOD LUCK!
    That thread was started in the middle of the summer in a hot climate. I don't think that's a co-inky-dink.
    Isaac Zachary likes this.
  5. Mendel Leisk
    40,471
    When I was monitoring temps on our 3rd gen, I can recall on a cool evening, say around 15~16C (60F), driving on an easy coastal highway, the battery was stable around 35C (95F).
  6. bisco
    51,027
    is the cooling fan running loudly?
    have you cleaned it and the intake grille?
    some have even posted debris clogging between the modules
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Under normal conditions, those are pretty high temperatures. But if the car had been sitting in the sun for several hours, the battery can eventually get as warm as the cabin, which can get seriously hot even when it's "only" 85 outside.
    If the car was in the shade, I'd expect temperatures between 95 and 105F. So, if you were parked in the shade, you might be seeing poor battery cooling due to a dirty fan or clogged fan intake. You can find out in a few minutes with a couple wrenches and a pair of eyeballs (even one eyeball is enough). ;)
