Gen 2 Prius ABS brake actuator clearing the codes?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by arya.eubanks, Aug 14, 2020.
  1. arya.eubanks
    arya.eubanks New Member
    Austin
    Hello,
    I'm very new at Prius. I just bought 2007 Toyota Prius and after a short time suddenly C1203 and C1345 codes appeared and ABS and brake light turned on. Is it possible that someone cleared these codes and warning lights before selling the car? ABS brake actuator warnings and codes can be dismissed? (PS: I've already tried the paperclip method)
  2. JC91006
    JC91006 Senior Member
    16,744
    8,551
    Anything is possible with a used car. The brake actuator usually displays symptoms of leaking pressure. The Prius ECU monitors everything in the car and if anything is out of spec, you get the warning lights.
    Since it seems you've driven the car a couple months, the actuator probably did not fail at the time you bought the car. It might have had symptoms of it leaking pressure the entire time (the constant rattling noise), but you were not familiar enough with the car to know there was something wrong.
  3. ChapmanF
    17,819
    C1345 code is no big deal. Car wants the linear solenoid offset learning procedure done. Do that, car happy, code goes away. Takes about two minutes.
    C1203 is more interesting, generally refers to a communication issue between the brake ECU and the engine ECU. On the other hand, its workup page in the repair manual starts with a note reminding you to do the linear solenoid offset learning. So I would be inclined to start there.
    Information on ways to access the repair manual is here.
  4. rjparker
    9,908
    6,112
    You can reset codes with an app and a bluetooth obd2 adapter combined with disconnecting the 12v battery for a few minutes. Realize you have one of the most complex cars on the road, absolutely complex back in 2007. It takes a Toyota scanner called Techstream to do many of the tests and procedures. It is expensive and there are some expensive aftermarket scanners that will do most things on a Prius. A good local Prius mechanic is a good starting point as many if not most problems will simply return after clearing. He could scan and clear easily. He could give you a better perspective based on years of experience. Otherwise you could start by disconnecting the 12v and then try an app like Dr Prius, Car Scanner or Torque. Adapter link attached.
  5. ChapmanF
    17,819
    Keep in mind that this car is not telling you that it wants its codes reset.
    It is telling you that it wants you to run a particular calibration procedure that takes about two minutes and will make the code go away.
    It will usually keep telling you that until that's been done.
  6. arya.eubanks
    Austin
    Oh all right. How can I do the particular calibration procedure or do I need to take the car to a service?
    Are C1203 and C1345 codes NOT related with ABS brake actuator?
  7. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Did you try un plugging the box next to the 12v battery and the battery it the abs back up power. I had to replace it after it kept doing the abs. It blows a fuse under the hood too. Once. Had to charge the caps inside the one from the junkyard it was dead blowing fuses every time I hooked it up (don't jumper fuse) add jumpers charge 12v remove jumpers
  8. ChapmanF
    17,819
    The OP posted the trouble codes already. They mean the car needs the solenoid calibration done. The OP should do the solenoid calibration. It's not hard.
    #8 ChapmanF, Aug 14, 2020
  9. arya.eubanks
    Austin
    Okay I googled and I did linear solenoid offset learning (or something like that).
    Now, red BRAKE and ABS lights are finally turned off! Thank you.
    I don't think my ABS brake actuator is bad. Dealerships are just pushing people to sell unnecessary repairs. And I cannot believe why Charles Maund Toyota Austin TX didn't calibration procedure at my car or didn't give information about it (they just did diagnostic at my car). Is there a specific error code or symptoms about ABS brake actuator? I will report this dealership to Toyota US.
    Best.
    rogerdpack likes this.
