Safest car jack capacity?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by berderder, Aug 14, 2020.
  1. berderder
    berderder Junior Member
    69
    Connecticut
    Hi all,
    I'm seeing some disparity in what people recommend for floor jack capacity. I have a 2014 which weighs about 3000 pounds.
    A lot of places recommend at least 2/3 or so of actual weight of car. So a 1 ton jack would be fine for a 1.5 ton vehicle.
    And then elsewhere I am seeing people use a 3 ton jack which seems overkill. But very safe? I am about to buy a jack and the larger capacity jacks are more expensive. However, safety is definitely number 1 priority for me
    What do you think?
  2. JC91006
    JC91006 Senior Member
    16,931
    8,640
    Don't buy from Harbor Freight
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,558
    2,598
    Taylors, SC
    If you own a 2014 Prius, a 1.5 ton jack would be fine. Lifting one end or one side is basically half the weight of the who car.
    There is a relief valve built in to the jack that does not allow the user to jack up more than the jack's capacity.
    berderder likes this.
  4. Mendel Leisk
    42,244
    I'm a lot more interested in the lift height. A 3 ton jack can typically do at least 19" unloaded. 20"~21" is even better. The rear/central jacking point is up pretty high; a lighter jack (with less reach) will barely reach it.
    I got a cheapo 3 ton (with about 19" lift) on a Boxing Day sale, for $69. about 15 years back. It doesn't see a lot of use, still works fine.
    Get some safety stands (3 ton at least, 6 ton too for higher lifts) and heavy duty wheel chocks too. Whichever end you're lifting, you should chock the wheels at the other end. I pretty much only lift at the front or rear central jacking points. Doing tire rotations for example, I raise the whole car and put it on safety stands. I prefer alternate points for placing safety stands; the scissor jack locations are for the birds.
  5. Georgina Rudkus
    3,558
    2,598
    Taylors, SC
    Really?
    My nearly 20 year old $60 Harbor Freight aluminum racing jack still works and does not leak. both left side wheels off ground.JPG
    2012 Prius v wagon 3 likes this.
  6. JC91006
    16,931
    8,640
    Really
    Grit likes this.
  7. Georgina Rudkus
    3,558
    2,598
    Taylors, SC
    No need. I have a special height riser block, pinch weld and secure locking system. front jacking.JPG front pinch weld close 2.JPG jacking front pinch weld.JPG rear jacking close.JPG
  8. Georgina Rudkus
    3,558
    2,598
    Taylors, SC
    Yes, really! It's in the attached photos of my previous post.
  9. JC91006
    16,931
    8,640
    I meant "really" don't buy a harbor freight jack or jack stands. They should lose everyone's trust when they recall jack stands and then give replacement jack stands that also gets recalled for failing.
    berderder and Grit like this.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    20 years ago, HF had great stands. Recently, they recalled stands that replaced another recall of a recall.
    Georgina Rudkus likes this.
  11. Georgina Rudkus
    3,558
    2,598
    Taylors, SC
    The jack stands are trash. The jacks are just fine. I use the best. Safejacks Rennstands and Esco models.
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Now that I have a garage, I'm looking forward to buying 12,000 drive ramps. Overkill 2X!
  13. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
  14. Georgina Rudkus
    3,558
    2,598
    Taylors, SC
    bshef and berderder like this.
  15. berderder
    69
    Connecticut
    What are the alternate points versus the scissor jack points?
  16. Georgina Rudkus
    3,558
    2,598
    Taylors, SC
    bshef and JC91006 like this.
  17. berderder
    69
    Connecticut
    Can you clarify which stands are trash and which products are good? What is that U shaped part on the jack in your photo? I’m still learning
  18. berderder
    69
    Connecticut
    You can place jack stands underneath the front and rear jack points? I thought that was a no-no
  19. Georgina Rudkus
    3,558
    2,598
    Taylors, SC
    I made my own "knife edge: pinch weld adapter that is an exact perfect fit for the Gen 3 Prius. I've made them for the $10 Walmart stand, too. custom prius rennstand adapter.JPG
  20. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    You jack the car up on those points, not held up by stands.
