Can ignition coil be removed without removing wiper assembly?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Robby2010IV, Aug 25, 2020.
  1. Robby2010IV
    Robby2010IV Junior Member
    Irvine
    Can all four ignition coils be removed without removing wiper assembly?
    Removing the plastic head cover exposes the ignition coils but I only get 2-3 inches clearance - is this why most DIY instruction starts with removing the wiper assembly?
  2. JC91006
    JC91006 Senior Member
    16,744
    8,551
    in gen 3 cars, you would need to remove the wiper cowl assembly
    Mendel Leisk and Raytheeagle like this.
  3. Grit
    Grit Senior Member
    6,571
    4,223
    Wilkes Land
    Right side driver turd gen models you don’t need to remove.
    Mendel Leisk and JC91006 like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,518
    Bay Area, California
    2019 Prius Prime
    Given the OP's locale is Irvine, I'm not sure they would have a right hand drive Prius ;).
    But it could be possible :whistle:.
    SFO, JC91006 and Grit like this.
  5. douglasjre
    douglasjre Senior Member
    2,147
    711
    Null, NL
  6. Mendel Leisk
    41,029
    Yeah and talk about oversight by Toyota: right side drive cars (Britain for example) yup, left side (North American etc) nope.
  7. ChapmanF
    17,819
    It's our fancy double-jointed windshield wiper that gets in the way.
    For some reason, the rain that falls in RHD countries does not require double-jointed wiping.
    If I'm not mistaken, even LHD rain no longer requires double-jointed wiping, if it falls on a Gen 4.
    jerrymildred and Mendel Leisk like this.
  8. douglasjre
    2,147
    711
    Null, NL
    I believe in removing more than just the wiper tray. Hoods can be replaced easily too....
    jerrymildred likes this.
  9. ChapmanF
    17,819
    Odd, I was able to change my spark plugs without doing that.
    But it wasn't raining.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,146
    Tampa, FL
    Well, that would make it easy to remove the coils. Was this a government job? :ROFLMAO::ROFLMAO::ROFLMAO:
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    There's a big benefit to removing the cowl you get to clean out the windshield water dam and flush out its 2 vents. If the car lives outside its got alot of leaf debris in there.
    Stick the garden hose in its vents and flush it out. Its probably just like the G2 vents out behind the front wheels.
    With the coil packs out you can look into the spark plug well and see if there's any oil in there very common for the valve gasket to leak there.
    A cheapo borsecope works good for that. here's a bs pic of my leaky vc gasket on my 07.
    You can see its just started to leak into the well and was not high enough to touch the bottom of the igniter. The plugs sides were not oily either. If i didn't look first I would have missed it I bet and would have eventually gotten a missfire when it filled it up more..
    If i was going to go through all this trouble i would replace the spark plugs too.
  12. douglasjre
    2,147
    711
    Null, NL
    Two of us replaced a motor. It was way more than the 8 hour job ppl here claim it to be. How the he11 does anybody do it that fast? And correctly? They're just not counting their diagnostic time, setup, clean up, engine sourcing/ordering, receiving, fluids purchasing, new water pump install, antifreeze fill, burping the hoses, filter change, goon stripped the header pipe bolt, oil fill, cleanup, put car on ground, hood and wiper tray removal/install and clearing codes plus test drive. Otherwise sure, 20.5h is feasable give or take
    #12 douglasjre, Sep 1, 2020
  13. douglasjre
    2,147
    711
    Null, NL
    Pix
  14. ChapmanF
    17,819
    Which of you was the goon?
  15. ASRDogman
    ASRDogman Senior Member
    7,460
    3,876
    Come on! It's a 3 or 4 hour job, TOPS! :LOL::LOL::ROFLMAO:
  16. jerrymildred
    11,517
    14,146
    Tampa, FL
    Or, as any manager worth his salt would say, "How hard could it be?" :ROFLMAO:
    ASRDogman likes this.
  17. Grit
    Grit Senior Member
    6,571
    4,223
    Wilkes Land
    As Garfield the cat in the cartoon series would say “they should be dragged to
    The streets and shot.”
  18. douglasjre
    2,147
    711
    Null, NL
    I let my auto body guy help out putting a cat in one of the other Priuses and and reattaching the header pipe on this one. Guess I overestimated his competencies
