The one and only Prius Plug-in FAQ!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by lensovet, Nov 24, 2012.
  1. bisco
    51,032
    yes, we're up to 8 years now and a couple hundred thousand miles experience here at priuschat. lifetime? unlikely
    LAHIRU GUNASEKARA likes this.
  2. 3PriusMike
    3,089
    2,411
    Silicon Valley
    Sure it will last a lifetime. Just unsure of whose life.
    So far 8 years and 3 months for my PIP's battery -- actually batteries. 12v is still original too.
    Mike
  3. hill
    8,622
    Yea . . . but the thing is . . . . when the capacity begins to diminish - your ICE kicks in - so many won't even notice. After all gas is inexpensive & many don't pay attention to lost capacity on an OCD level. So the question may better be framed .... how MUCH capacity will be lost - in how much time .... and in different climates. After all cooler - more temperate climates are much easier on a traction pack, than hot places are. Problem is - MOST buyers are in areas that get LOTS of summer heat - & the Prius is air cooled.
  4. bisco
    51,032
    you will notice with a plug in, as range diminishes
  5. bisco
    51,032
    wow! i replaced my 12v a year ago, but i attribute it to sitting for two months every winter while i was in florida
    3PriusMike likes this.
  6. LAHIRU GUNASEKARA
    LAHIRU GUNASEKARA Junior Member
    Srilanka
    I have also 2012 plug-in last month I serviced it & checked the HV battery status service dealer says that I’m still having a 99.9%. Of a battery. I don’t how is going to end up the battery life.
  7. bisco
    51,032
    that's excelent! (y) i didn't even know dealers could do that
  8. hill
    8,622
    must admit - my snifOmeter did go off when I read that. Especially after all of the other Oddball things that the service centers have told me.
  9. bisco
    51,032
    1/10th of one percent per 8 years, that battery will outlive all of us put together
  10. LAHIRU GUNASEKARA
    Srilanka
    Hope long life for our Li ion batteries
  11. buta17
    buta17 Junior Member
    wilminton
    2012 Aqua
    I
    I think YES!
    question: are HV and EV batteries located together? or separately ? hv near the seat, EV in cargo
  12. buta17
    wilminton
    2012 Aqua
    I
    Is it possible to replace regular prius hv batteries with Plug-in's batteries?
  13. john1701a
    john1701a Prius Guru
    12,794
    5,276
    57
    There is only 1 battery. It is divided by capacity.
    13% to 84% is reserved for EV.
    8% to 12% is reserved for HV.
    Above 84% and below 8% is reserved for longevity.
    buta17 likes this.
  14. buta17
    wilminton
    2012 Aqua
    I
    Thank you Sir!
    PriusPiP likes this.
  15. bisco
    51,032
    no,
    there used to be some kit, but since the plug in is so cheap, they all went out of business
