trunk-lid spoiler/wing issue
Discussion in 'Gen 2 Prius Main Forum' started by andreaswin, Jul 16, 2006.
  1. andreaswin
    andreaswin New Member
    72
    NORWAY
    hi!
    washed my car today and i found that there is something wrong with the spoiler /wing on the trunk-lid.
    its higher on the left side than on the right side.. seems like its a bit loose on the left side (can move it up and down a little on that side )
    So before i start removing plastic covers....anyone know how to tighten it up or how its secured secured to to the lid.....???
    cheers Andreas
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Well there are clips on each side of the spoiler as well as one in the center. There are 4 bolts across the under side of the spooler. You may want to hit the spoiler gently but firm on the side thats sticking up. It may have came out of its clip but a good tighten spoiler should not do that. The clip may also be broke. To tighten the bolts you first have to take the bottom plastic panel off which is a pain and you my brake some clips in the process. I broke 1 when removing mine. Then you have to remove the center plastic thats between the 2 glass windows. Then you will have access to the 4 bolts.
    Go here for some pictures.
    http://priuschat.com/index.php?showtopic=21246&hl=spoiler
  3. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Some '06's, mine included, seem to have a spoiler that doesn't align with the quarter panels...the one on my car is close to even on both sides, though, and I've chosen to just leave it like that.
  4. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    of course, with it being a new car, you could always ask the dealer to fix it...
  5. Pinto Girl
    3,093
    350
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 12 2006, 02:47 PM) [snapback]331881[/snapback]</div>
    ..or just admit to yourself that our cars are imperfect machines designed by perfectly imperfect beings, and leave it alone.
    With my luck, at least, the dealer will probably do more damage than anything else.
  6. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Pinto Girl @ Oct 12 2006, 12:32 PM) [snapback]331866[/snapback]</div>
    Totally normal. They're all like that. As long as it is even, there's nothing anybody CAN do about it!
