Visible wheel balance weights
Discussion in 'Gen 2 Prius Main Forum' started by richard schumacher, Oct 11, 2006.
  1. richard schumacher
    7,664
    1,045
    United States
    A remark by Dan the Man made me go look at my wheels: there are no wheel balance weights visible anywhere on them.
    What about this? Are balance weights needed only with replacement tires? If there are factory weights, are they mounted on the inner rim facing the car? (Presumably they are not inside the tire, unless the factory has some very sophisticated balancing technique...)
  2. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(richard schumacher @ Oct 11 2006, 10:35 PM) [snapback]331520[/snapback]</div>
    From the factory, there are weights on the inside of the rim, i.e, not the back rim, but the inside facing the wheel hub attached with some sort of adhesive, on my Prius. You should be able to see them through the spokes of your wheel if you remove the trim ring.
  3. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    Mine are on the inside edge of the rim, results in a much cleaner look.
    Dan.
  4. Orf
    Orf New Member
    414
    Devonport, Tasmania
    When wheels are properly balanced after a tire change, they should be balanced both circumferencely and laterally. This may cause weights to be added to the inside and outside rim right next to the tire.
    The balance weights attached with adhesive sound like wheel balances put on to the metal wheel before the tire is fitted.
