Fuel indicator blinking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tim826, Oct 15, 2020.
Tags:
  1. Tim826
    Tim826 New Member
    L Eco
    Hi brand new. Had a 2006 prius donated to my Nonprofit. When I turn it on the gas gauge blinks 2 bars briefly before all 10 bars start blinking. It wont switch into drive or reverse. And the combustion engine wont start. I replaced the 12 volt battery, and filled the gas tank full. Any ideas before I scrap it? Its catalytic converter was stolen and they put a straight pipe on it. It's possible the muffler broke off? Also it was really low on oil. I put in a quart. And the brake fluid was at minimum.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    So, the fuel gauge will always show one blinking dot any time 12v power is removed and restored. This will clear once the fuel gauge recalibrates itself. Could be 2 minutes or 2 days.
    Your situation is a bit different
    This type of blinking is indicative of a network communication problem. Could be connections, broken wire, ecu, etc. Is it a repeating pattern of blinks?
    PriusCamper likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,036
    1,965
    NJ-USA
    You are starting off in a pretty big hole with this car. No ICE function, won't shift, no cat, - who knows what shape the high voltage battery is in. Unless you need a parts car or enjoy trying to fix a basket case, I'd scrap it and move on.
    If you want to try to go further you would need a Toyota compatible scan tool to see what codes there are in all of the car's modules. If there is a network comm problem (the scantool might not be able to talk to the car) then you have a whole new can of worms to deal with. Can be very challenging to figure that kind of thing out.
    Tim826 likes this.
  4. Tim826
    Tim826 New Member
    L Eco
  5. Tim826
    Tim826 New Member
    L Eco
    Sorry it took so long to get back on here. Its is just 10 bars blinking. No pattern. Just a steady blinking.
