PRIA started screaming!
Discussion in 'Gen 2 Prius Main Forum' started by Michgal007, Oct 13, 2006.
  1. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    Today I started the car and drove for 20 meters and I heard some noise. I thought it was some outside noise so I ignored it. Then people on the street started starring at me. I rolled down the window and realized it was coming from PRIA. It was SO loud, I am sure people who were a block away could hear it.
    Seemed it came from the tires. I didn't have ANY warning lights on. When I stopped the car, the noise stopped. When I was moving slowly, the noise was coming out slowly. When I accelarated it started screaming. More like metal scraping.
    I got SO scared. I put my blinkers on and then turned off the car. Then started again and the sound was not there anymore. I drove for about 10 miles afterwards, and no noise.
    What could it be? The temp is about 20-30F and I didn't let it warm up. Any advice please. I am going on a big road trip tomorrow!!!
  2. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    <div class='quotetop'>QUOTE(Michgal007 @ Oct 13 2006, 12:05 PM) [snapback]332409[/snapback]</div>
    A loose engine drivebelt might make a noise like that. Also maybe a rock stuck next to the brake caliper, or a brake splash shield may be bent and making intermittant contact with the rotor. These have all happened to me, but not on my Prius. Good luck. Intermittent problems are the hardesrt to find and fix.
  3. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    I would lean towards something with the brakes. Something like a rock stuck next to the brake caliper (as subarutoo suggests), or something else that was causing the brakes to squeal. From your description, I sort of doubt it was a loose engine belt, since it was probably fairly likely that the ICE wasn't running for *some* of the time you were driving.
  4. sl7vk
    sl7vk Member
    518
    Salt Lake City
    I'm sorry, but I'm chuckling right now. That entire post is priceless.
    I hope you get to the bottom of this though...
  5. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    probably something in the brakes. happens often enough.
    what drive belt? :D
  6. Michgal007
    1,321
    98
    Macon, GA
    <div class='quotetop'>QUOTE(sl7vk @ Oct 13 2006, 03:29 PM) [snapback]332424[/snapback]</div>
    Do explain why you find this funny. I am a first time driver and it scared me half to death.
  7. eclectcmoi
    eclectcmoi Muffinologist
    6,764
    17
    Lakewood, CA
    I have years of driving experience and still hate car issues of any kind. You just feel helpless not knowing what's going on. Hearing such a loud and obviously wrong noise coming from Pria, would scare me to death too Michgal007!
    I hope it was something to do with the brakes like the other posters have suggested and your trip goes safely and smoothly.
  8. sl7vk
    sl7vk Member
    518
    Salt Lake City
    Everything from the subject of the post on down is hillarious to me. Trust me, I've been there. The car "screaming" the people staring the panicked feeling. Just the way you put it all into words was priceless. That's all.
  9. Alnilam
    Alnilam The One in the Middle
    760
    Carlsbad, CA
    <div class='quotetop'>QUOTE(sl7vk @ Oct 13 2006, 01:26 PM) [snapback]332457[/snapback]</div>
    Well, I can be as serious as you.
    Prius is masculine, if you count the word as a noun in Latin. (I don't)
    Pria is feminine. You performed a sex-change operation on your vehicle! Bad dog! You ever hung around a woman very long before she started screaming at you? And you know you deserve it.
    I rest my case.
    (But I feel your pain and hope you find the solution. I suspect brakes, although they last forever in this car. Mileage?)
  10. jamarimutt
    jamarimutt New Member
    985
    The same thing happened to me... the loud shreeking noise from the brakes that went away by itself after a brief stop. In my case, the ABS system failed about a couple of months later, out of warranty. :(
  11. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Here's another theory: Perhaps the parking brake was not released the first time you started off. After you stopped to consider the problem, you set and released the parking brake normally.
    This situation can also happen if the parking brake cables pick up some ice and don't release completely, even if you release the brake.
    What I find odd is that you still thought the sound was "outside noise" for almost 20 miles. After a few blocks, did you just assume something noisy was following you? :)
  12. chimohio
    chimohio New Member
    460
    I've had work drive belts sound like they are screaming. You didn't mention your mileage but I'm gonna guess it's not a lot. If it comes back stop and feel all the wheels around the brake pads to see if they are hot. Might tell you something.
  13. Michgal007
    1,321
    98
    Macon, GA
    <div class='quotetop'>QUOTE(Rick Auricchio @ Oct 14 2006, 08:36 PM) [snapback]332873[/snapback]</div>
    No I meant 20 meters, not 20 miles. I don't usuallly put parking brakes on, so it wasn't there.
    <div class='quotetop'>QUOTE(jamarimutt @ Oct 14 2006, 06:26 AM) [snapback]332660[/snapback]</div>
    Oh, thanks for letting me know. I only have about 2500 miles on it, just bought the car 6 weeks back. I called my dealer and she asked me to bring it, so they can check it out. I drove about 300 miles today and the car gave me no trouble.
  14. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    It has happened to me twice now. Both time a bit of plastic caught in the front caliper. First time I could not figure it out, but it happened just before I got home. It sounded like it was coming from the left front. When I got home I got my wife to stand in the driveway and listen while I drove it back and forth next to her. On the second time a bit of plastic flipped out and she grabbed it. It looked like the clear plastic covers for on of those water bottles with the pop open and close tops. The second was a round piece of blue plastic that looked like it came from a plastic pop bottle. Both were pretty chewed up and both made a horrible noise almost finger nails on a black board. The tire must flip them up under some situations. In my case it was late in the day sunny and warm in the 80's FWIW
