Dill's Prius Saga
Discussion in 'Gen 2 Prius Main Forum' started by DLMcKenzie2004, Nov 1, 2020.
  1. DLMcKenzie2004
    DLMcKenzie2004 Junior Member
    North Carolina
    Hi everyone! Dill here! I will be posting my adventures with my 2008 Prius in this thread to keep everything related to my car in one place. You can find my first post and the backstory to the whole car adventure here:
    New owner! Making a Dice Roll on a $1000 '08 Prius! | PriusChat
    TLDR; Got a 2008 Prius at a government auction for $1125. Was sold as not able to go in gear but when jumping from the battery it would start and drive! I was the only person who eyeballed it during the inspection window so I had more confidence going into the auction process. I felt even with the red triangle on the dash, it was worth the $1125 as it was state-maintained and they keep up with the maintenance really well.
  2. DLMcKenzie2004
    North Carolina
    This past Friday me and my wife loaded up our F150 in anticipation to drive the 4 hours to the Prius and expect to have to tow it home. On the way to its location, I stopped at a dealer nearby and tried to buy a battery and touch up paint. Fun fact, the prices online for the dealership are different than what you pay at the parts counter! They would not be willing to match their own online pricing on the spot and told me it could take a while to process my order if I placed one immediately so I left. I went ahead and placed an order online for a dealership up the highway closer to the car and picked it up there no problem and saved ~$45 from what I would've paid in-store, bleh.
    So the whole way up there I am nervous, my wife didn't go look at it with me the first time and this would be her main vehicle after all. Happy wife, happy life. I knew she approved of the color but was not sure if she would like the Prius in general. My biggest fear was something would go wrong and it would not start or drive and would give a bad first impression. So we get to the car and I get the title and keys. Fortunately there was a DMV across the hall from where I got the title from the county office. I went over and quickly paid my taxes and got a 10 day temp tag. Ready to roll!
    I get out to the car and its time to install the new battery. I quickly take out the old battery and proceed to pull all the rubber plugs to drain the water that has leaked in the trunk. It was rusty orange water on the battery compartment side but I think it was from the battery tray or something else, the body of the car looked fine. I could not, however, remove the spare tire. The gray plastic nut was on good! So that had to stay on until I could get home. After draining all the water I install the new battery and put everything back together. I sit in the drivers seat and hit the power button... it starts! At this point I am quite happy. I brought along 3 gallons of gas since the car showed as empty but the car acted like it wouldnt take any more fuel. I was confused about this but it didnt take long before the gauge updated to show a full tank.
    My wife is overall quite happy, but doesnt like the smell the stagnant water had left in the car, we will take care of that later. The red triangle was still on but I was surprised to find it would turn off and turn on repeatedly. I thought the red triangle certainly meant it would only turn on once and never again. I insert my OBD tool and get the following codes: P3000 and P0AFA I do a quick search and see a few things but no time to fix that, time to get home! So we start the long 4 hour drive home. According to the screen I was averaging 41 MPG by the time I made it to my house. The car drove wonderfully, but certainly not like it was supposed to. The ICE stayed on constantly, I had read it doesnt always stay on, also the battery on the screen would never fully charge and really by the time I got home it was green but 1 bar was missing. It took forever to get to that point but never discharged during the trip. It was about 3 bars when I first started the car. I am also totally unsure of what the Prius is supposed to sound like normally so I hear things and wonder if they are normal. Like I hear the engine quietly. Sometimes when I brake I hear the actuator for a few seconds but not always. When I turn off the car I hear the coolant pump for a moment. I managed to find explanations to make me feel better about all the noises. The only one I couldnt explain was a mechanical kind of whirl noise similar to a mechanical motor or something. It changed in pitch as I would go faster and was not dependent on the engine or turning. Not a wheel bearing I am sure. Maybe it is norma but I just have no clue without any real reference!
    The car drove wonderfully really the entire way home. I could tell it was so well maintained. The tires were in great shape, no noises when going over bumps, drove in a straight line and handled magnificently. On top of that, the interior was in surprisingly good shape and it looked like just a little bit of elbow grease was in order to get it nice and clean. I think my wifes biggest issue was all the chips on the hood! I think someone followed behind a dump truck and got a ton of rocks thrown on them, not sure! Hopefully the touch up paint does enough magic to make it good enough. We will be doing the initial wash and such tomorrow, making sure the exterior and interior look good and seeing how much better it looks with a bath. We will probably do a compound and polish too in the coming weeks but right now I want to focus on fixing the red triangle issue.
    So, lets chat about that a moment... The red triangle codes look to be dealing with either the ECU or the battery itself. My thoughts are to pop the cover off and visually inspect the battery first. Read voltages, check the ECU internally and the plug for any corrosion or heat damage and then look at the BUS bar. I am concerned the issue with the battery could have come from the amount of water in the trunk, really who knows how long or how much water had got in there over time. It was a lot when I got to it. One thing is for certain, I am not opposed to buying a new battery. Looking at NewPriusBatteries (I think thats what it was called) I see I can get a battery from them for $1600. But my local dealership will sell me an OEM one online for $1699 (plus a core charge, but I would return the old battery). I dont really know what would be the best step forward on that choice if it comes to it. Any suggestions or thoughts on that topic or any of the others I have described in my post?
    Here are some photos from pick up day!
  3. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    My first suggestion is for you to buy an old Windows 7 laptop and a pirated Mini VCI cable and set your generic OBD II reader on the shelf. Ebay and Amazon have the mini VCI cables by the truck load. This is most likely the cheapest and most effective DTC reader for our vehicles. If you can confirm you have code P0A80, again, IMO your best bet is to buy a new HV battery from a dealer of your choice. You are dealing with a vehicle that is approaching 13 years old with a component that had a service life of 10.
    These are fantastically reliable cars all things considered.
    .02
    DLMcKenzie2004 and fotomoto like this.
  4. fotomoto
    fotomoto Senior Member
    5,626
    3,802
    So. Texas
    Get a new HV battery and your life with an old prius will be MUCH more enjoyable. Start a fund for other repairs (brake accumulator, main dash display, inverter pump & valve are the most common).
    DIY folks should have a good working copy of techstream installed on an old laptop (xp or vista machine but newer setups can be made to function).
    DLMcKenzie2004 likes this.
  5. fotomoto
    5,626
    3,802
    So. Texas
    Common sign on a highway commuter especially as they get older.
  6. DLMcKenzie2004
    North Carolina
    Thanks all! I appreciate the feedback and responses so far. When I changed the 12v battery I couldn't find a date on it? I wonder if the 12v that was in it was the original. Would be crazy for a 12V to last so long but it was an OEM battery.
    @M in KC the codes were P3000 and P0AFA. I did not notice a P0A80 code (yet). I am computer saavy so I will get an old computer loaded with Windows 7 and get techstream and the OBD reader. Do I have to use a specific type of USB OBD tool? I use a OBDLink EX OBD Adapter for my Ford vehicles when I use the Forscan program which is similar to techstream but is a third party software designed specifically for Ford vehicles. It was supposed to be real fancy but no clue if Techstream only wants a specific type of USB OBD tool.
    I am not opposed to just getting a new battery. I might go with the one from newpriusbatteries even though the cost seems in-line with the OEM one, I would not have to worry about the Core thing.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    I have a NPB system and it works great but nothing beats the factory modules for proven long life.
    Its a new car with a new battery the power comes from the battery. So if the cost is close go with the factory battery's. In my area there is no $1600 factory battery's.
    But make sure your original factory battery has not been whack a mol'ed and a few modules have already been replaced becasue from what I understand the dealer will not accept your core if its been whacked and it does not have consecutive serial numbered modules. That's a $1350 + hit on your plan.
  8. PriusCamper
    PriusCamper Senior Member
    11,980
    4,870
    Pacific Northwest, USA
    Congrats on a great car... You error codes point to corrosion in the battery pack's voltage sensor harness ($50 part). Usually this corrosion causes damage where it plugs into the battery ECU but a used ECU only costs $50... Also learn about battery reconditioning...
    Contrary to the money wasting people above who don't know any better, you don't need a new battery pack yet and with the right care and maintenance you have some solid years left in this one.
  9. DLMcKenzie2004
    North Carolina
    Thanks, @edthefox5 and @PriusCamper I will have to check the battery. I also apologize if my posts are popping up oddly, I am still new so they have to be approved first. My plan was to pop open the battery first to check the ECU first. I was thinking I may as well check it and the wiring for any obvious problems before I ordered a new battery since there was a chance I would order a new battery and have this ECU problem anyway. I also have no way to know if this battery has been replaced before even though the description said: "battery has never been replaced". The person that listed it was not able to give me any service history so I doubt they know what services have actually been performed. I'll try to get pictures of what Dr. Prius says as well. I went ahead and ordered the Mini VCI, looked like it uses a special chip that techstream needs.
    A local seller is selling a Maxx Volt lightly used for $200 but it looks like it is only a charger and not a discharger. I have read a bit about reconditioning but it seems from most posts to be only delaying the inevitable if the battery actually is going bad.
    Gave it a good wash today
    Did a ton of touch up painting on that hood. I can still see all the spots obviously but at least they arent white!
  10. PriusCamper
    11,980
    4,870
    Glad to learn that you're competent in electronic stuff. You're gonna have fun working on this car... Some thoughts based on your responses:
    --Techstream is essential for bleeding brakes and a few other things, but a hassle to set up. Dr. Prius App is super easy to use and reads all the basic error codes and subcodes that you'll need to for most diagnostic problems and as long as you buy a good OBD2 it's the first tool I usually use. Here's buyer's guide: Hybrid battery diagnostic and repair tool for Toyota and Lexus
    --I'm right now working on an 2008 Prius that appears to have the original 12v that I'm going to replace because this one drops down to 10v after two days. So it's not uncommon for them to last a ridiculously long time. What's different with Prius 12v is that other than running in Accessory with the car off, which for most people doesn't happen often, the battery's only job is to turn the computer on, which turns the hybrid battery on, which charges the 12v and that's it. No engine starter amps being pulled from the 12v either, as HV battery handles that.
    --Reconditioning is more valuable than you might think. Toyota designed the packs to run at 50% capacity without warning lights to avoid the basic reality that all NiMH needs to deep cycled and they'd rather sell expensive new battery packs than properly maintain the old one. When done correctly reconditioning your >50% capacity will be restored to 96%, which makes a huge difference in driveability.
    --$200 for MAXX volt is a bit high as it charges as a constant 1/3 of an amp and doesn't use the NiMH algorithm, which creates pulsed charges which help break up the poorly conducting crystalization in Nickel based batteries. Sometimes you can find Prolong chargers used online for $200ish and they have a super rapidly changing variable of NIMH algorithm charge that shifts from .001amp to .999amp, which is far superior. As for Discharge, you just need to wire up two light bulb sockets in series, not parallel and add a multi-tester that can handle high voltage readings. HybridAutomotive sells these but sound like you have to skills to build one. The user manuals on their website has all the discharge numbers you need for proper reconditioning.
    --Another option is to pull the pack and deep cycle each of the 28 modules that are 8.2v each. I use a 12v 50W halogen for each module discharge and then I use these RC hobby chargers to charge each module back up: iMAX B6 V2 Changer Below is a pic of my latest rig to do this work. It's a bit primitive and I added extra 20v bulbs to speed up the process, which is cheating a bit as a slower discharge is better.
    --Also check in with your local auto wrecker about spare HV battery packs for Prius. I've often bought them for as low as $50 and that way you can rebuild one pack while you still have use of the car and then you have a spare pack on the shelf for swapping out in an hour whenever you or a friend has a bad pack. And the joy it brings to someone that has a stealership quote them $4K to repair their Prius and you tell them you can do it for less than $400. I so love that!
    --Each Module has a serial number on it and enclosed below is how you translate that info to know month and year of manufacture of each module and as long as all those numbers match it hasn't been rebuilt before:
    --Here's a pic of the part # you'll need to get rid of your red triangle... It's so sad how many people give up their Prius because the Stealership tells them this error code means your have to spend $3K on a new pack and $800 on a new battery ECU when in truth it's only $50 for the "Wire Frame" and $50 for a used battery ECU, but most ECUs just need their pins cleaned and aren't yet fried. That's all you need to fix your problem. I see this all the time. Most common cause of death of a Prius as far as I'm concerned.
    #10 PriusCamper, Nov 2, 2020
  11. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
    No need anymore for old Win7 or XP laptop with techstream. Finally able to post links.
    TOYOTA Techstream V15.10.029 (05/2020) + Activation - MHH AUTO - Page 208
    Important!! Note link for MVCI Driver for x64 OS Win10
    MVCI Driver for x32/64 OS Multi Version - MHH AUTO - Page 1
    Get MiniVci cable for $14.99
    Cheapest MINI VCI for TOYOTA V14.20.019 Single Cable Support Toyota TIS OEM Diagnostic Software
    #11 alftoy, Nov 3, 2020
  12. DLMcKenzie2004
    North Carolina
    @PriusCamper I appreciate your input. I went ahead and took apart the interior quite extensively to get to the battery ECU. Uh oh, looks crispy... Taking apart the connectors and the ECU it looks like this:
    Pin 22 is GONE. The surrounding pins are also in quite bad shape. The actual board itself looks fine. It is a real shame there are no after market 22 pin connectors that I could just solder in. I have a very nice soldering station and would not be afraid to do it. I checked and see nothing though. I guess I will order a new battery ECU and Wire frame first then put everything together and see if our angry triangle problem is solved. While I have the cover off the battery, is there anything else I need to check? I almost feel like I should install what is needed to do a rebalancing. Seems a useful investment even if I did ultimately need a battery.
    On the bright side! I got an email from the state sending me ALL service records for the vehicle in a nice PDF format. I do see in 11/15/2019 they took it to a Chevy dealer (lol) for service where they replaced the front pads and rotors. The notes in the invoice says "Idles rough CEL has came on but not on now. Never had plugs and wires" also says "not shifting correctly" IDK what any of that means but I do notice it might idle a little odd. I assumed it was like that because the engine really shouldnt be idling other than to charge the battery which I guess isnt done quite right when you have the ECU issue like I have now. I also think fixing the battery thing might help with "shifting" but I may do a transaxle fluid drain and fill since I dont see it listed. I did notice on the highway if I tried to press the gas pedal it would seem to go to neutral before going back in gear. In reality it looked like from the display that in that moment it tried to get the battery to power the car for a split moment before switching back to the ICE which is why it feels like it goes out of gear. Again, I imagine my battery issue might fix this? They also said to check wheel bearings then note "all wheel bearings seem fine at this time".
    Another few things I see is this mystery word. Short Out pipe?
    They had fixed the heat shield at the rotors, a whole bunch of tire changes (the state seemed to do a tire change yearly) and a recall fix for the gas pedal (2010), steering shaft/hybrid water pump (2013) and at one point a new combination meter and keys in 2014. There are also so many oil changes on record that it seems they just did it anytime they felt like, which is probably good. Receipts show synthetic has always been used.
    Oh! Before I forget. I noticed this somewhat corroded wire near the fan. Looks to lead to the passenger tail light or somewhere in the bumper?
    So here I am, guess I should order the ECU and Wire Frame now? Anything else I need to go ahead and order while I have this thing apart? What about the nuts that go on the battery posts or any kind of protection from oxidation and corrosion?
    #12 DLMcKenzie2004, Nov 3, 2020
  13. edthefox5
    10,096
    4,830
    Clearwater, Florida
    The ecu damage on the wire is very common. The corroded pin on the fan connector is even more common. Like just about all G2's you have a bad cabin leak. if you get a flashlight and look in the hole the 12 volt battery is sitting in you will find aquatic life and maybe a few ducks swimming around. Under the spare tire is usually a tropical paradise. Both have rubber plugs that can be removed to drain the water.
    The leaks come from where the hatch valley meets the roof. Where the quarter panel meets the roof in the valley you will see putty'ed over spot welds at that seam and cracks there leading up that valley up to the roof that run up the body channel underneath the black plastic strips on the roof. Those strips pop right off. Leak pretty good right there at those cracks and leaks down inside of the car into the hatch.
    Which begs the point the car has lived outside and probably has mice damage too. Take the cabin filter out from behind the glove box see if theirs a Mouse Days Inn being built in there and then open the air filter box on top of the engine. Look for mice bunk beds in there the little freeloading bastards.
    fragglestickcar and fotomoto like this.
  14. DLMcKenzie2004
    North Carolina
    Whew! I am back! Is that connector the fan connector? None of the wires seem to lead to the fan. Not sure though. As I mentioned in the first post, I did drain the water that had accumulated. I will have to fix this so it will be nice and dry!
    As for mice, I did not see anything. The cabin and air filter looks almost new. They did keep up with the maintenance and it was detailed last year so maybe they cleaned anything I might would find? It seems okay. I had a car with mice once. Was a disaster!
    So I pulled the battery out today. It was heavy but I brought it inside my house. My wife is not too happy, especially when I told her it might be sitting here for a while depending on how I go about charging and discharging it a few times. Someone locally is selling a B6AC charger but I see that would only do one module at a time with an estimate of about a month to do it all haha, my wife would kill me.
    So here is what it looks like!
    I did see some liquid but not much. I assume its normal?
    Anyway, as you can see... super corroded. I remember in Dr. Prius every block was green and the same level except for block 1, it was all the way in the red as low in the red as the others were high in the green. Looking at the sense wires, it seems block 1 (furthest from ECU?) is the wire that leads to the burnt connector. So maybe the pack is "fine" after all. I have a multimeter but I am notoriously famous for misplacing things so I am going to buy another and check the current voltages on each cell and update later. I ordered the Wire Frame and ECU. I guess I will just find a way to clean up the copper bus bars for the other side and all the nuts.
    I really like the idea of being able to grid charge the whole pack. I dont mind taking it all apart but man it seems like a pain if I had to do it regularly. I also dont mind spending money but $500 on the prolong seems nuts if I can just drop $1600 and get the NPB and just be good for a while and not worry.
    Lastly, the mini VCI and techstream stuff came today but... Obviously the prius battery is removed. So I guess that does me no good right now haha.
  15. fotomoto
    5,626
    3,802
    So. Texas
    This. The time of trying to maintain this battery has past.
    Did you notice the liquid droplets on a couple of those modules?
    edthefox5 likes this.
  16. DLMcKenzie2004
    North Carolina
    Yeah, my thought at this point is mostly just to replace the ECU, which would have had to be done anyway. The bus bar wouldve probably been changed with a new battery so really this as of now is only a $55 journey down a path that might not even yield a positive result. Getting a multimeter and a cheap battery charger would only add another $20 but those are tools I could always use in the future for other things. To go all out, as I mentioned in my last post, just doesnt seem to make much sense unless I was only trying to get the car to last me another year or so or was getting it good enough to flip.
    Those droplets were only on a very few and it was just that tiny bit I saw. I did notice the top of the battery cage had some corrosion on it on the side of the sense bars at the corner furthest from the ECU.
    For now I put the copper pieces in a salt and vinegar bath, I cant believe theyre looking better already. I wonder what overnight would do.
    Thanks again for all the replies so far!
  17. edthefox5
    10,096
    4,830
    Clearwater, Florida
    Don't bother with the copper pieces if your thinking of NPB's. They come with all new hardware, cables & Interconnect. Only thing they dont replace is the battery ecu.
    You have cracked modules there and there leaking. If you kept driving it would have thrown a Ground fault code. If the wife's gonna freak out with one pull she will really freak when you have to pull it out multiple times if you WAM it. (that's what she said)
    "Whack A Mole" battery rebuild.
    I should have trade marked it.
    So go with the highly recommended NPB system if you can afford it its a highly engineered battery system pretty easy to install. I installed one & lots of help on this site.
  18. DLMcKenzie2004
    North Carolina
    Read the voltages on the battery. Heres what I got (working towards the BCU). I was surprised all the voltages were near 8v per module. I usually see them in the 7's on other posts people make here. Maybe its the crappy Harbor Freight multimeter? The first few modules which read lower I believe are the ones on the end of the connector that was burned.
    1. 7.93
    2. 7.94
    3. 7.94
    4. 7.93
    5. 8.0
    6. 8.01
    7. 8.0
    8. 8.03
    9. 8.0
    10. 8.01
    11. 8.01
    12. 8.02
    13. 8.01
    14. 8.0
    15. 8.0
    16. 8.01
    17. 8.0
    18. 8.01
    19. 8.01
    20. 8.01
    21. 8.0
    22. 8.02
    23. 8.0
    24. 8.02
    25. 8.0
    26. 8.0
    27. 7.99
    28. 7.99
  19. dolj
    dolj Senior Member
    8,184
    4,167
    Wellington, New Zealand
    Unless you have codes that say otherwise, I'd just stick with replacing the No2 wire-frame, the ECU and, cleaning up the bus bars and nuts. I'd then just bolt it all back up and do a full (3-cycle) disch/chg recondition with the Maxx charger. Build your own light-bulb discharger to do the discharges.
    I don't see any other reason to be unhappy with the HV battery for now.
  20. DLMcKenzie2004
    North Carolina
    Went and bought the Maxx Volt. Got it for $150 from a guy about 2 hours away who used it a handful of times. I went ahead and put the battery connections all back together and the battery is "hot" on the table in my living room charging while a box fan blows on it. It was 221V when first connected. The Maxx Volt says it will charge until it is 240-245ish. I guess by that point it should be fairly balanced and we will be good to pull the safety plug, haul it outside to the car and see what she does.
    I gave up on using the hobby charger on each module, it really was taking a long time and I was not able to source a good DIY discharge setup so I was using alligator clips connected to a old headlight bulb until it turned off at a little over 6v. I could maybe build a discharger for the battery to use alongside the Maxx Volt I got. Their discharger is like $300 so a DIY solution may be in order. I have seen them here but cant recall where. It would be real nice to be able to use the Maxx Volt plug to do it all so it stays neat. Its a 9 pin twist connector. No way its proprietary.
    If we can get it good enough to drive with no light to pass the state inspection, that will buy me some time to drive around the car a lot and evaluate that there are no other issues before we decide to keep it and get the NPD. I am assuming nothing prevents you from halfway reinstalling it in the car, meaning bolting the battery and cover down but leaving the interior out?
    EDIT: Found the Maxx Volt connector. Its apparently a CPC (Circular Plastic Connector), 9 pins or something usually made by Tyco amongst others. I see the word AMP thrown around with it too. Found them on ebay so might order a connector and look at fabricating a DIY discharger using it. Heck, you could make your own cable to permanently mount in your car easily and people could just pass around the same Maxx Volt in the area. Would just need the connector, the right kind of wire, an inline fuse and some eye-type connectors to go on the battery terminals.
    #20 DLMcKenzie2004, Nov 10, 2020
