15 year old sticker removed - how to restore paint
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by OptimumPrius, Nov 20, 2020.
  1. OptimumPrius
    OptimumPrius Junior Member
    17
    Frisco Texas
    I bought my 2005 Gen 2 from the city at auction. Under the 15 year old stickers, the white paint is shiny and perfect. So there are shiny number shapes on the paint.
    I’ve tried cutting compound on the surrounding dull paint to blend it all in to no avail.
    do I just need to strip the top coat where the stickers were?
    any advice appreciated
  2. pasadena_commut
    pasadena_commut Senior Member
    2,651
    789
    Southern California
    On a 15 year old car? Ignore it.
    edthefox5 likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    #3 TMR-JWAP, Nov 20, 2020
  4. OptimumPrius
    17
    Frisco Texas
    Ha! I like that. There's numbers all over the body though :(
  5. OptimumPrius
    17
    Frisco Texas
    Maybe I watch too many restoration shows where they take valuable relics and make them shiny. I just bought into the shiny dream.
  6. AzusaPrius
    AzusaPrius Senior Member
    2,184
    921
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    The problem is not residue but areas of the paint which are faded or oxidized differently.
    If he lets it sit out in the Texas sun for another 15 years, Mother Nature will probably solve it for him. :ROFLMAO:
    Pretty sure that there is nothing easy you can do to improve the appearance, short of a complete paint job.
    Check with a body shop or two.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,974
    NJ-USA
    Lightly wet sand the shiny spots with 1500 grit sand paper then use rubbing compound on the whole area.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Clay bar the shite out of it,
  10. sam spade 2
    7,035
    2,803
    2017 Prius c
    It is nice the people are trying to help BUT............
    After 15 years, it is very likely that the paint has faded unevenly because of the stickers.
    That means that the base actually is a slightly different color where it was not exposed to the elements.
    If that is the case.....there is NOTHING easy you can do to "fix" it......including sanding, finishing compound or clay bars.
  11. orenji
    orenji Senior Member
    5,887
    3,488
    Repainting or vinyl wrap are the only true solutions.
  12. PriusHead05
    PriusHead05 Member
    318
    Use Meguiar's Ultimate Compound. That's the only compound that worked on my heavily oxidized white 2005. Just make sure you use a cotton/terry towel. If you use a microfiber towel, it will leave a residue.
