wire harness hold down bolts under the engine cover
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by vvillovv, Oct 29, 2020.
  1. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    I noticed my wiring harness hold down bolts are not centered in the in the wiring harnesses holes.
    I'm just curious if the Prime comes that way from the factory because I don't see a reason why anyone would be messin around with the engine top wire harness at this point in the cars life cycle.
    If anyone has noticed yet or remembers to look next time the hood gets opened, pull the engine cover and look at the 2 or 3 bolts that hold down the wire harness just under the cover. If you can see any of the silver metal around the harness holes and the boltdown looks a bit off center, that 's what I'm seeing.
    I can think of a couple of maintenance procedures that would require the harness removal, just none of those
    maintenance items are on any of the cars service records.
    Thanks for reading...
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,463
    2,424
    Taylors, SC
    That's a common assembly method for non-critical elements.
  3. vvillovv
    4,321
    1,510
    NY
    Thanks for your comment
  4. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    My guess is it’s designed that way to provide some slack to the wires. Just maybe touch up paint the exposed area so it doesn’t rust on you...
  5. vvillovv
    4,321
    1,510
    NY
    Thanks for the suggestion @jzchen I'm mostly concerned with do others with Prime see the same from the factory?
    I'm trying to figure out whos and whats been tinckered with while I haven't been looking.
  6. Mendel Leisk
    41,407
    What services have been done and by who?
  7. vvillovv
    4,321
    1,510
    NY
    evap code: Dealer Service in Vriginia Beach (watched tech hookup techstream (took 10 minutes max)
    2 year free Dealer services every 5k or so
    body shop - replace passenger door skin - How did that happen, CV Axle | PriusChat
