If anyone is wondering, yes you can fit a 70" boxed TV in a Prius.
Discussion in 'Gen 3 Prius Main Forum' started by Rainking, Nov 25, 2013.
  1. DanAlchemy
    DanAlchemy New Member
    Pittsburgh
    I was able to fit perfectly a 70" TV in its original box, tilted while entering the car and then laying it flat (apparently not recommended but I had no issues), so I was able to close the hatch! (Prius 2015). Very roomy car, I have carried mattresses, couches, even live trees! I don't think a 75+" TV will fit, probably the 70" is the limit.
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    Try a 40 gallon boxed water heater...I did and I closed the hatch to boot. If you’re British either way will work.
  3. Siward
    Siward Active Member
    311
    126
    Toronto
    Most would probably think that you would maximize the space by putting the front seats forward.
    I actually found that you get the most space by putting the backrest of the front seats all the way down. It would be difficult to drive and would be a bit dangerous. In the case of the TV, I would lean against the box instead of the seat backrest for the short trip home.
