buying used 2017 Prime (150,000 km) worth it ?
Discussion in 'Prime Main Forum (2017-2022)' started by Ozmit88, Dec 9, 2020.
  1. Gokhan
    Gokhan Senior Member
    6,153
    2,433
    Paramount CA
    It's certainly not available in the US because it doesn't meet the rollover-crash safety standards, and it's not clear if it has ever gone beyond a prototype in Japan. It doesn't seem to be a very useful feature. It's better to install solar panels on your house to charge your car.
    #41 Gokhan, Dec 16, 2020
    jerrymildred likes this.
  2. Trollbait
    12,507
    What, that solar roof? It's been an option on the Prius Prime since its introduction. It's only available in Japan and Europe.
    The official reason for it not coming to North America is that it shatters during a roll over, which means failing US regulations. It also isn't a cheap option. Convertered yen price was $3000. A European poster also said you have to give up some other options to get it.
    Discussion about it here.
    Some new information on the non-US bound solar roof | PriusChat
    Last year, they revealed a prototype that had more advanced PV cells on the roof, hood, and hatch, including the rear window. that one could provide power to the traction battery while the car was running.
  3. bisco
    51,851
    the solar battery
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    I can't find a solar battery option on the Toyotas website. Do you have a link?
    @Tideland Prius, you seem to know a lot about what's going on with the various options. Have you ever heard of a solar battery in North America on the Prime? Other than unfulfilled promises?
  5. bisco
    51,851
    not in n/a, but toyota cheaped out and used the same design here, throwing in two seats and hoping no one would complain.
  6. Tideland Prius
    16,549
    No, not in North America.
    I think what @bisco is talking about is the small NiMH battery that the solar roof charges. This battery then charges the Li-Ion traction battery in the Prime. The solar roof doesn't actually charge the Li-Ion battery directly.
  7. Trollbait
    12,507
    The solar battery is part of the solar roof system that is optional in other markets.
  8. Gokhan
    6,153
    2,433
    Paramount CA
    I'm not sure if the solar panel and/or NiMH solar battery charge the traction battery at all. The YouTube video is showing that they only power and/or charge the 12 V system, which would have a small effect on the fuel economy and/or EV range.
  9. jerrymildred
    11,517
    14,148
    Tampa, FL
    So what do European models have to do with the original question posed from North America? Clearly, the extra hardware in Europe is not what prevented Toyota from using a thee passenger arrangement in the back of NA models.
  10. Trollbait
    12,507
    Overall, potential weight of the car. This a Prius. The bigger battery is a big source of added weight, but Toyota also wanted the solar option. The design needs to account for the heaviest trim. The solar roof option means forgoing some other high trim options. Weight could be a reason for doing so*. They've already taken out the spare and rear wiper, and added a carbon fiber hatch. Eliminating a seat with attending passenger was needed.
    When asked, around the time of the introduction, about 5 seats, it was stated that the weight of a fifth passenger was an issue, and reinforcement would be needed. Moving the charger wasn't a big deal. So Toyota either adding the reinforcing, or dropped the maximum design weight somehow. I lean towards the former, as the solar option doesn't appear to equal the weight of a person.
    *weight considerations may not be for engineering, but weight bins for regulation testing.
    Tideland Prius and jerrymildred like this.
  11. jerrymildred
    11,517
    14,148
    Tampa, FL
    So, apparently they can have the solar charging in some markets but not others. But they can't have five passengers in some markets but not others. :confused: I always assumed it was weight and not space regardless of the small amount of weight added by the solar option. Apparently, they have made the necessary strengthening changes. And probably figured out that there won't be many 250 pounders trying to wedge themselves into that middle spot between two other adults.
    Wait! I think I figured it out. Americans, on average and compared to much of the world, are HUGE. :D
  12. Tideland Prius
    16,549
    That’s partially incorrect.
    The solar panel augments the 12V only when the vehicle is on.
    When parked, it can top up the battery (via the small NiMH battery), allowing for 1,300km of solar EV driving assuming an annual average of 3.5km per day.
    Gokhan likes this.
  13. Gokhan
    6,153
    2,433
    Paramount CA
    Ah, OK, so can it actually charge the traction battery through the solar battery? What is the capacity of the solar battery in terms of kWh?
  14. Gokhan
    6,153
    2,433
    Paramount CA
    Tideland Prius likes this.
