Hey, P1121 code so I replace my valve. Code came back, so I tested the old valve and it did its thing. Now I have two working valves. The electrical connection looks great. Could it have a short? Any thoughts or suggestions... Thanks, gregwco.
Did you bleed all the air out of the coolant loop? Where did you get the replacement valve? Is it an OEM product?
Sorry, a lot of hours at work. Yes, the coolant system is clear of air and full. Dorman product, I have never had a problem with them in the past.
