Toyota Prius 2018 (strange headlight)
Discussion in 'Gen 4 Prius Technical Discussion' started by douson, Dec 21, 2020.
  1. douson
    douson Junior Member
    US
    Hello everybody. I bought a left headlight. I immediately saw two problems. The turn signal light has a different connection. And the most important thing. This headlight has additional lights. Has anyone had experience with this? Photo below.
  2. douson
    US
    I found the answer. )
  3. Mendel Leisk
    40,242
    Care to share?
  4. douson
    US
  5. douson
    US
    I have a Prius Four, but what kind of headlights I can't find information.
  6. Elektroingenieur
    2,515
    3,275
    Three Touring
    For model year 2018 Prius cars, parts catalog Figure 81-01, Headlamp, lists two versions of the left headlamp unit assembly. To find the correct one, you have to know how Toyota in Japan identifies the grades, which don’t correspond one-to-one with the U.S. marketing names.
    The part labeled “ZVW51..H” (81070-47741) is for Touring models, and the part labeled “ZVW5#..B,E,G” (81070-47711) is for other models, including your Prius Four. The letters H, B, E, and G correspond to the grade indicated in the model code, such as ZVW51L-AHXGBA for a Three or Four.
    douson, Mendel Leisk and alanclarkeau like this.
  7. douson
    US
    Thank you so much ...
    krmcg and Elektroingenieur like this.
