Can you top off the inverter coolant and engine coolant?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SpeedDemon, Mar 18, 2021.
  1. SpeedDemon
    SpeedDemon Junior Member
    31
    Los Angeles
    I noticed that my engine coolant and inverter coolant are a bit low. Can I just get some coolant from my Toyota dealership and top off both reservoirs or do I need to bleed both systems?
    I have a 2014 Prius with about 73k miles on it.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Top off
  3. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    then clean egr.
  4. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Yes you can.
    moto g(7) power ?
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    IF.....the levels are not really below the LOW or ADD marks when cold, then they are not really "low" and you need to do......nothing.
    But if it will make you feel better, then yes get some "pre-mixed" coolant from the dealer and top them up......when cold.
  6. SpeedDemon
    31
    Los Angeles
    Thank ya'll. I'm getting my car recalled for the Inverter and reprogramming of the ecu (read: less MPG). Will pick up some coolant while at the dealer today.
  7. sam spade 2
    7,035
    2,801
    2017 Prius c
    IF......you have a decent dealer, THEY should top up the coolant while they have it.
    And needing to do that more than once a year or so is NOT a normal thing.
  8. ChapmanF
    18,151
    I don't read it that way. You can if you want to.
