Trouble running after sitting 6 months. Dealership baffled.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Thamnophis, Mar 24, 2021.
  1. Thamnophis
    Thamnophis New Member
    Iowa
    We stupidly let our 220,000 mile, 2008 Prius sit through the winter while we needed only one car - the newer Prius.
    It started up after an overnight charge (the battery was completely dead after sitting so long thru a very cold winter). It ran OK as we drove into town to get gas, but wouldnt start up after filling up.
    Had it towed to the dealer where they re-set the computer. They told me it was sending erroneous signals to the engine and after resetting the computer the car ran fine.
    Back home we started it the following day after night temps in the 40s. The electric system fires up, then after a minute the engine fires up and runs normally. After about 30 seconds though th engine starts to choke and sputter and shuts down.
    After 5 or so times of this I put the car in gear as soon as the engine kicks in and it continued to run as long as I had the accelerator depressed. As as soon as I let off the gas the engine sputtered and died again.
    I did this several times but eventually just backed out of the drive and headed down the road. After a hundred yards the engine stopped again. At this time the battery indicator showed it was on a single bar. I was able to charge the battery up to 3 bars while sitting in the drive with the car in D and my foot on the gas. But the charge quickly diminished as I started and re-started the car.
    I drove a mile, restarting the car less and less frequently the more time the engine was running. After a mile or so I was able to keep the engine running and the car charging. By the time I got to the shop (not the Toyota dealership) the car was running OK and the battery showed it was almost fully charged.
    But as this has happened now 3 times, Im sure it will be another huge hassle tomorrow morning. Anything I can help the mechanics consider? They seemed perplexed when I explained the symptoms.
  2. JC91006
    JC91006 Senior Member
    16,762
    8,562
    Maybe your 12v is dead? You can try resetting the car again by disconnecting the 12v battery negative for a minute and see if it'll start up normal like at the dealership
    Thamnophis likes this.
  3. bisco
    51,843
    stale gas
    privilege likes this.
  4. privilege
    privilege Active Member
    659
    169
    Birmingham
    I would pull the fuel line and dump half the tank into a can. then start it up again with fresh gas
  5. Thamnophis
    Iowa
    I wondered about that. I asked the mechanic and he said they'd add some gas - the tank was nearly empty when I drove it in.
  6. rjparker
    10,085
    6,256
    Your engine normally stops many times after it warms up. If it has starting problems it will have those issues as it drives. Clearly your 12v battery is history, your fuel system is highly questionable (injectors, fuel pump, bad gas) and your hv battery is likely poor.
  7. Stevewoods
    Stevewoods Senior Member
    659
    1,125
    Seattle, WA
    A real WAG -- but:
    Does the engine need to "relearn" it's idle?
    When I had dead batteries on a couple of non-hybrid rigs in the past decade -- not the Prius -- I had some trouble with the engines stalling out until the computer relearned the idle settings -- it was particulary frustrating on my Camry and took several days to futz around with until the computer was satisfied. Symptoms you are experiencing sound somewhat similar.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    This.
    Start with the 12 V battery, including checking the OTHER end of the main battery cables.
    Then some Gumout or Berrymans B12 in the gas.
    If it continues to act up after that, then hopefully some codes will show up.
    BUT.....do you really want to spend time and money on a car that old ??
    There are few real mechanics left anymore.......and even some of the better ones seem to know nothing about batteries and electronics.
    Thamnophis and Stevewoods like this.
  9. Stevewoods
    659
    1,125
    Seattle, WA
    Have to agree with the "too few" real mechanics nowadays. A friend was having trouble with his Camry a few years back and explained it to me. I said it sounds like you need a new fuel pump.
    He took it to the dealer -- this Camry was a "pre-computer" model. The "techs" were baffled. He was told it was a very difficult problem -- made even more difficult because there was no computer to tell them what was wrong.
    He then took it to an independent shop I recommended. A family shop. The 72-year-old current owner had inherited the shop from his dad. Most of the mechanics are guys who keep their teeth next to their bed, although they have a couple of youngsters.
    The owner heard the description of the problem and said -- fuel pump.
    It was the fuel pump.
    BTW, the young guys at the shop are the ones that usually handle the hybrids! :D
    #9 Stevewoods, Mar 24, 2021
