I can’t believe I fixed my oil burning for $7
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 6ixPrius, Mar 24, 2021.
  1. 6ixPrius
    6ixPrius New Member
    Toronto
    My Prius has 343,000km(212k miles) bought used was burning around 1 quart every 2500-3000km
    I did all the usual fixes like pcv, cleaning maf and full tune up.
    finally coming from Honda’s all my life which had valve cover gaskets as routine maintenance item when you do valve adjustment I decided to pull of the valve cover on the Prius
    the gasket was basically baked into the metal and came off in chunks and the rest needed to be scrapped off.
    i replaced it with a new fel pro gasket and now it’s been almost 4000km and only burned 150-200ml of oil.
    Meg&Bear and Sanchan like this.
  2. ChapmanF
    18,079
    Are you sure the oil wasn't just leaking before? Not easy to get into the cylinders and burn, through a valve cover gasket.
  3. Mendel Leisk
    41,334
    Could it be the failing valve cover gasket was letting air get sucked in, messing up PCV valve operation, or pulling oil up into combustion chamber somehow. If OP’s oil consumption has indeed dropped dramatically with that one change, something was going on.
  4. bisco
    51,845
    i can't believe it either
    edthefox5 likes this.
  5. ChapmanF
    18,079
    OIl leaking out of an engine also lowers the level in the crankcase.
    jerrymildred likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    Hooda thunk it, right? :D
  7. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    So the O.P. found out that his valve cover was leaking? I don't see an explanation other than he states that it was brittle, changed it out and now it burns less.
    TomK
  8. Rmay635703
    Rmay635703 Senior Member
    2,668
    1,687
    Somewhere in Wisconsin
    2013 Chevy Volt
    This is a very common issue on the gen I volt, can even cause coolant to disappear
    only difference on the Volt is there is an inner and outer valve cover gasket that require replacement
    Would be excellent if this was the actual issue on all PRII
  9. ETC(SS)
    7,134
    ....or even many of them.
  10. privilege
    privilege Active Member
    659
    169
    Birmingham
    burning oil
    vs
    leaking oil
    they both show on the dipstick, but fixing one does not fix the other.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Lots of posters just messing with us....or the world really is going mad.
    privilege likes this.
