Gas mileage versus distance driven
Discussion in 'Gen 4 Prius Fuel Economy' started by Ramo_958, Apr 9, 2021.
  1. Ramo_958
    Ramo_958 Junior Member
    22
    Doylestown, Pennsylvania
    2018 Prius
    I commute 19 miles to work. Today I checked the gas mileage at different distances. The temperature is 50 degrees which is also a variable. At 5 miles I got 42 mpg, at 10 miles I got 50 mpg, at 15 miles I got 58 mpg and at 19 miles I got 58.5. My conclusion is that the car needs at least 10 miles to warm up.
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    It's variable due to a number of factors - I suspect a 19 mile drive has little to do with it - maybe the first kilometre or 2.
    What is the traffic density? Speed? Traffic lights or not? Topography? State of charge? You could also be more relaxed too in the later part of the journey. All these, and more are likely to have more to do with your mileage.
    What's your reverse journey like?
  4. Ramo_958
    22
    2018 Prius
    "What's your reverse journey like?"
    I usually get 54 mpg on the way back home due to topography as you mentioned and also different traffic pattern. This is in the suburbs of Philly.
  5. bisco
    51,510
    my gen2 used to warm up fine on my 14 mile commute, maybe after 1-3 miles in winter. i would average 50mpg or so on 5 miles of back roads and 2 miles at 55mph
    alanclarkeau likes this.
  6. sclevine
    sclevine Active Member
    149
    149
    NE Florida USA
    2024 Prius
    At 50 degrees, were you running the heater? In my experience that is a very big drag on mileage, and especially affects warmup when using car first thing in the morning. But maybe not a factor if your car sits in a garage overnight.
    I could also argue that the car was warmed up after 5 miles since at that point it pretty quickly went from 42 to 50 (ie: it averaged well over 50 between miles 5 and 10)
    Only time I notice a 'warmup' issue is when it is cold out.
    FuelMiser likes this.
  7. fuzzy1
    10,337
    What you observed was the mathematical effect of amortizing the fuel burn needed to warm up the engine block / coolant / catalyst, first over just a few miles, and then over ever-increasing numbers of miles. The more miles you can spread out this cold-start penalty, the less it drags down your final MPG.
    The best way to determine when the engine is warmed up is to watch its coolant temperature. For this, use any aftermarket OBDII-port engine monitor. I use an archaic ScanGauge-II, but there are many other products available.
    P.S. Here is a spreadsheet result of your MPG for each segment of that trip. Accuracy is limited by whatever rounding you did, but I'd say that your engine was already adequately warmed up for great MPG even for the whole segment between 5 and 10 miles. I.e. it was already warmed at 5 miles, but you still needed to spread that cold-start penalty over additional miles before seeing a good total-trip MPG.
    #7 fuzzy1, Apr 9, 2021
    PaulDM and jerrymildred like this.
  8. Mendel Leisk
    40,954
    More-or-less off-topic rant, but anyhoo:
    It used to be ANY car that rolled off an assembly line had a bonafide coolant temp gauge.
    alanclarkeau and fuzzy1 like this.
  9. alanclarkeau
    7,045
    7,592
    My last 2 didn't.
  10. fuzzy1
    10,337
    My first Prius was my first car with no temperature gauge.
    But while my '97 Subaru had what looked like a temperature gauge, a ScanGauge revealed that it wasn't bonafide. The entire temperature span from 145F (or less) to 200-something+ was collapsed to a single point. It otherwise revealed only very low or very high conditions. Apparently that was another element of "customer expectation management".
    MIkeDr and Mendel Leisk like this.
  11. alanclarkeau
    7,045
    7,592
    The FORD mechanic said to me that they dropped them (FIESTA) because "the average driver doesn't look at them till it's too late" so the computer will 1) flash red lights; and if no attention paid, 2) turn the engine off or limp mode - he wasn't sure.
    jerrymildred and fuzzy1 like this.
  12. fuzzy1
    10,337
    I.e. the same reason BMW abolished engine oil dipsticks. At least for a while, though I remember hearing of it returning on one model.
    ... and in the same vein, we now have drivers upset when they discover their cars don't have a flashing red light for low oil.
    jerrymildred and alanclarkeau like this.
  13. alanclarkeau
    7,045
    7,592
    I don't recall a light for low oil - just catastrophic oil pressure. But I did have an oil temperature gauge on a VW Air-cooled engine.
  14. PaulDM
    PaulDM Active Member
    616
    319
    UK
    2022 Prius
    Excel
    Interesting stats
