2020 L Eco electric motors
Discussion in 'Gen 4 Prius Main Forum' started by priusmatty, Apr 16, 2021.
  1. priusmatty
    priusmatty Active Member
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Just for fun, I was trying to come up with the number of electric motors contained in my 2020 L ECO. So far I have:
    1. 2 under the hood.
    2. Grille shutter mover.
    3. One for each window.
    4. Power steering.
    5. Probably braking system activator or something?
    That's 9 so far. Am I close?
    jerrymildred likes this.
  2. ChapmanF
    18,078
    Engine water pump.
    Inverter water pump.
    Yes, in every Prius there is a motor that pumps up brake fluid pressure.
    But in Gen 4 they added two more. So I think you've got three of those.
    Three in the heating/AC to move doors around. Does yours have separate driver/passenger settings? Probably at least one extra there too.
    The HVAC blower is a motor. Is there still a battery cooling fan? Motor.
    Each door lock/unlock actuator is a motor. Hatch release actuator is a motor.
    EGR valve actuator is a motor. There is probably still a leak check pump in the EVAP system back by the fuel tank. Motor. And of course there's the fuel pump. Motor.
    Have you got two radiator fans? Don't forget those. (Or if those were the "2 under the hood" you meant, then don't forget the big two in the transaxle.)
    The one that moves the transaxle in and out of Park.
    Two in each side mirror. (Do you have fancy mirrors that self-fold? More motors.)
    Do you have power seat adjustments? Lumbar adjustments?
    All Prii (to the best of my knowledge) have seat-belt tensioners that activate in a crash, but those aren't motors, they're bombs.
    But I think some newer Prii also have pre-collision seat-belt pretensioning ... motors.
    I think we might be getting close now.
    Front windshield wiper.
    Do you have a rear windshield wiper?
    Washer pump motor. Another for the rear, if you have those. Another for headlight washers if that's a thing in L Eco.
    Headlight level adjusters (2) if that's a thing in L Eco.
    Throttle actuator. That's a motor.
    #2 ChapmanF, Apr 16, 2021
  3. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Haha so how many is that total???
  4. ChapmanF
    18,078
    Total is left as an exercise for the reader.
    priusmatty and alanclarkeau like this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    markrivers likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    Isn't the steering also a motor?
    Edit:
    Sorry. Matty had that in the original post.
  7. alanclarkeau
    7,045
    7,592
    Petrol filler flap?
    Sliding Roof?
    There's the Rear heater outlet control servo.
  8. ChapmanF
    18,078
    I didn't know if an L Eco had a sliding roof.
    Is there a separately controlled rear heater outlet?
    The petrol flap in the generations I'm familiar with (1 through 3) is released by a simple Bowden cable pulled by a lever on the floor. Pretty bulletproof tech. Have they gone electric for that?
  9. PaulDM
    PaulDM Active Member
    616
    319
    UK
    2022 Prius
    Excel
    Mirrors (2)
    Boot release
    AC blowers (2 I think)
    Battery cooler fan
    Door locks (4)
  10. jerrymildred
    11,517
    14,148
    Tampa, FL
    Gen 4 has a push button on the dash.
    alanclarkeau and PaulDM like this.
  11. ChapmanF
    18,078
    A fuel filler door with a progress display. There's an image that's going to stay with me.
    alanclarkeau and jerrymildred like this.
  12. Mendel Leisk
    41,334
    Hybrid battery fan motor
    alanclarkeau likes this.
  13. jerrymildred
    11,517
    14,148
    Tampa, FL
    Two of them in the PiP & Prime. :whistle:
  14. alanclarkeau
    7,045
    7,592
  15. alanclarkeau
    7,045
    7,592
  16. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Fuel pump been mentioned yet?
    It is electric.
  17. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Man, there must be 20+ electric motors lol
  18. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    "There must be 50 ways to move your lever"
  19. ChapmanF
    18,078
    Ok, five HVAC servos then. compared to three for gens 1 through 3.
    Post #2.
    My favorite is still the fuel door with a progress display.
  20. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    haha
