2013 dead battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Laurie Tilson, Apr 20, 2021.
  1. Mendel Leisk
    40,467
    Maybe just a lot of names being tossed out, and in reality they’re all doing the same thing. The amp rating will determine how long it takes to full charge, is all.
    Laurie Tilson likes this.
  2. Laurie Tilson
    Laurie Tilson New Member
    Rochester, ny
  3. Laurie Tilson
    Rochester, ny
    The date on the 12v is Jan 19, so it's just over two years. I took it in last night, they looked it up on carfacts and yes, indeed it's only 2 years, done at a toyota dealer and under warranty. I believe Toyota said two or under covered in full.
  4. Laurie Tilson
    Rochester, ny
    Ty. Seeing it was only serviced the at one Toyota place it was easy to look up with the vin #. The way it's in there I couldn't easily see the date with unhooking everything. Battery should be replaced today.
    Samuel Williams Jr likes this.
  5. bisco
    51,024
    problem being, they won't warranty if it tests good
  6. Laurie Tilson
    Rochester, ny
    Well ... let's hope they have some integrity and do the right thing.
    bisco and Samuel Williams Jr like this.
  7. Laurie Tilson
    Rochester, ny
    Okay we are getting somewhere.
    I'm not getting a new battery. YET.
    Battery dead when they started working on it.
    They found the 12v at 225 ma out 342 which they say is good.
    They found an after market Verizon obd2 interface turned on, so they unplugged it. It's used to communicate data from the car to alert customer.
    Hopefully this is the fix.
    If not they said they'd replace battery.
    Total today's cost ziltch, zero, nada. thanks and hopefully I won't need you too much in the future.
    bisco and sLick415 like this.
  8. Laurie Tilson
    Rochester, ny
  9. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    Thats good for now. I'd still find out how old the battery is. if it is original you probably should just replace it anyways, at 8 years its on its last leg if original.
  10. Laurie Tilson
    Rochester, ny
    Sorry. It tested 325 cca out of 344 cca, so thats good.
  11. Mendel Leisk
    40,467
    That might have been 225 CCA* tested, 342 CCA rated? Which is NOT good: a typical healthy battery will read well above rated. For example, a 325 CCA rated battery might read 350~375.
    The typical electronic load tester would likely “fail” a battery having CCA lower than spec. Charging a battery in that state would raise voltage some, but do little or nothing to the CCA.
    *CCA = Cold Cranking Amps
    addendum: you posted correction about the values while I was typing. Again, anything lower than spec is NOT a battery in good shape.
    a Solar BA9 is something you can pick up relatively cheap, and see for yourself.
    Laurie Tilson and Grit like this.
  12. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    You work undercover for solar ba9 company!!!
    bisco and Mendel Leisk like this.
  13. Mendel Leisk
    40,467
    Age is maybe secondary? I’ve got an Optima Yellow Top, will be 6 years old next September, rated 450 CCA, read 490 last time I checked.
    bottom line: the best (maybe only) way to dispel 12 volt issues, is to educate yourself, and get all the relevant gizmos/tools. As long as you’re relying on dealership or Pep Boys, it’s gonna be “complicated”.
    I do draw the line. AC maintenance for example, I just grit my teeth and bring it in. But 12 volt batteries are pretty straightforward.
    #33 Mendel Leisk, Apr 22, 2021
  14. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    to send ping signals for geolocation tracking, not bad in case an alibi is needed.
  15. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    No, that is not a really good test for the 12 V battery in a hybrid because.......it really does not DO cranking duty.
    Voltage is more important than cranking amps.
    The OBD device was "hot" all the time and no doubt sapped the battery.
    NOW it needs to be manually recharged with a small charger overnight at least.
    But once it has been discharged, it's life is likely reduced.
    If it was old to start with OR it was left in a discharged state very long, it likely is toast now.
  16. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    gotta love how the easy fixes are skimmed over on here :cool:
  17. Mendel Leisk
    40,467
    The battery may not start the engine, but I respectfully propose that as-tested CCA is still a good indicator of the battery’s viability.
  18. Samuel Williams Jr
    246
    Dayton NV
    In theory, that makes sense. I use both but I never thought about either?? So I looked it up and found this.
    https://www.oreillyauto.com/how-to-hub/battery-charger-maintainer-differences
    It does not address using a "Battery Maintainer," to charge a battery. But it does mention that you can't use any old "Maintainer," on a AGM battery?? I think that one is a my "Bad," on my part??
    But as to using a "Battery Maintainer," to actually charge a Battery?? I suppose, but in the "Real World," who does that?? Just saying. :)
  19. Samuel Williams Jr
    246
    Dayton NV
    Aww well I missed my opportunity to test that theory!
    The DVOM said the battery was good?? But the car would not start and the resulting key fob madness and lock out's and no starts followed. My better half got tired of my foolishness and drove the car to the Hybrid Shop and that battery was out of there! :(
    But I still wanted it. because while it would not start the Prius. I wondered if it would start a normal car???
  20. Ed Beaty
    Ed Beaty Active Member
    334
    310
    Salt Lake City
    "But as to using a "Battery Maintainer," to actually charge a Battery?? I suppose, but in the "Real World," who does that?? Just saying."
    At least two people do: I do, and Mendel does, as we both don't drive the car all that much. We use a CTek maintainer (4A). Excellent piece of gear. Just saying.....
