BEWARE! Gen 3 catalytic converters are as easy to steal and Gen 2's.
Discussion in 'Gen 3 Prius Main Forum' started by Georgina Rudkus, May 2, 2021.
  1. xliderider
    xliderider Senior Member
    8,038
    3,212
    Honolulu, HI
    I made a ramp so I can roll the floor jack up onto the riser. Almost threw out my back lifting the jack when I was test fitting it on the riser.
    I also decided to take a minimalist approach for the platform, there's only 4x4 blocks under the wheels of the jack instead of the whole platform being solid wood (heavy)!
    Just have to fasten everything down and add some wheel stops and side rails so the jack can't roll off the riser. 20210508_121407.jpeg 20210508_121548.jpeg
  2. Mendel Leisk
    40,495
    Pyramid builders in your ancestry? (Rhetorical :))
    Merkey and xliderider like this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,343
    2,337
    Taylors, SC
    I have Scepter ramps that I regularly use for oil changes, Race Ramps, the Quick Jack 3500, but my favorite is the Safejacks Rennstands which provides 16-1/2 inch of clearance.
    If you raise the front pinch weld, the rear tire is at least two inches above the ground, where I can support with an Esco jack stand.
    Just raising one side allows easy access to many components including the exhaust system and easy tire rotation. best jackstands.jpg That's what I used to paint the catalytic converter, preheater and resonator.
    DogDaze, wr69 and xliderider like this.
  4. xliderider
    8,038
    3,212
    Honolulu, HI
    Finally installed the cat shields today. I didn't use the ramp I built in the end.
    I was able to get 16 inches of clearance below the frame rails. It was still a tight fit working under the car, and getting enough leverage on the rivet tool and drill to bore the necessary extra holes was very difficult.
    I couldn't get enough leverage on the rivet tool on stainless steel 1/4 inch rivets, so I ended up using the included all aluminum rivets.
    It's so uncomfortable working under the car, I'm hoping that any thieves don't want to spend time drilling out the rivets to remove my stainless steel mesh reinforced cat shields.
    Sorry for the backwards pictures, I used the selfie mode on the front camera, so the pictures are mirror images. 20210508_205403.jpeg 20210508_205429.jpeg
    DogDaze, wr69, mikey_t and 6 others like this.
  5. privilege
    privilege Active Member
    659
    169
    Birmingham
    I know folks are trying to prevent theft, but a jerk with a cordless Metabo wheel ... wouldn't even take a minute to get through those pieces of sheet metal.
    for that matter, a skill saw would do it, and sound like regular old construction to anyone that noticed.
    it might be money well spent to use an after market cat that is much much cheaper, and sell your high dollar oem for profit.
    tashaviaf likes this.
  6. Grit
    Grit Senior Member
    6,414
    4,182
    Wilkes Land
    on my way now to cut off my oem cat to sell off and replacing it with a aftermarket to come out ahead. The aftermarket cat would deter theifs and I get a new bottle of wine, win win!
    #26 Grit, May 9, 2021
  7. xliderider
    8,038
    3,212
    Honolulu, HI
    For those who have installed cat shields, warning stickers or no stickers on the windows?
    For home security systems, there's two schools of thought on yard signs and window stickers. Warn thieves away, or advertise the type of security system you have, so that they know it's weaknesses and make it easier to steal from you.
    Raytheeagle likes this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    No stickers on mine;).
    I'll let the surprise be evident when they put forth effort:).
    It should elicit the "move along this won't be easy" response(y).
    DogDaze likes this.
  9. xliderider
    8,038
    3,212
    Honolulu, HI
    Just saw this OfferUp listing in Honolulu, someone's selling steel bolt on cat shields from $450 and up.
    I'd say, with the wording on the shield's, I would think that you'd end up with at least a heavily keyed car, or a smashed window. Screenshot_20210509-072431_OfferUp.jpeg Screenshot_20210509-072420_OfferUp.jpeg Screenshot_20210509-072409_OfferUp.jpeg
  10. privilege
    659
    169
    Birmingham
    cool. are you replacing a gen 3 cat ?
    I'm not finding much info about 3rd generation aftermarket replacements. as soon as I do, I'll remove my OEM and replace it, pocketing the difference
  11. privilege
    659
    169
    Birmingham
    $20 worth of steel sheet and $10 worth of plasma cutter time = $450 "kit"
    and you still gotta pay a welder ($$$$) to dab it into place
  12. Mendel Leisk
    40,495
    Tried something today. Will see how it holds up, invite opinions. Got very solid once I torqued all the nuts. If I’m happy with it I’ll maybe heat up the accessible nuts and wick solder into them.
    4BB3CB7A-683C-460E-92B0-EC31975B2C74.jpeg D897731D-8FA5-45EB-B5E2-E6AA46418D36.jpeg 4099B5CC-AB8D-4C32-BCBC-206BFE9BE926.jpeg 28D33672-A683-4E43-B59C-C6928F161C23.jpeg
    Bill Norton, DogDaze, mikey_t and 5 others like this.
  13. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    I love your Chain method, doesn't it Rattle?
    ScottHz likes this.
  14. Tekken
    Tekken Member
    257
    77
    It's pain in the A$$ that Cali Smog Check require to check the CAT, if we Rivet the CAT Shield, it needs to un-Rivet the nut every 2yrs prior Smog Check
  15. Mendel Leisk
    40,495
    Don’t know yet; haven’t driven. It was slightly loose at first, but once I torqued the 3 bolts at the surface it tightened up solid. I’ll watch for that and update.
    ccna101 and ScottHz like this.
  16. PriusII&C
    PriusII&C Active Member
    370
    130
    San Jose, California
    Do you speak from personal experience? Before riveting the sheild to my Prius a few months ago, I talked to a smog check station owner, and he informed me of no need taking the shield off if the catalytic converter is the original. My smog check is a few months away, and I hope I don't need to take the shield off.
    #36 PriusII&C, Apr 10, 2022
    ralph seifer, ScottHz and DogDaze like this.
  17. crooner
    crooner Member
    107
    Yucca Valley, California
    I smogged my Gen 2 late last year with the cat shield installed. No issues whatsoever. My 2015 is still a year away from requiring a smog check. Both cars have the cat shields riveted...
  18. Paladain55
    Paladain55 Active Member
    401
    159
    The South
    Honestly, the only question I have is do the aftermarket cats work well for these cars? They were always hot garbage when they came with the exhaust kits for mustangs (long tube headers etc...) you might get a year or two and then the internals would collapse and plug (around 10 years ago). If only these cars were as easy to flash as domestic cars then we could just do cat deletes and move on lol.
    ScottHz likes this.
  19. Mendel Leisk
    40,495
    That's apparently a bad idea, solder doesn't really bond to steel that well. Permatex Red thread-lock (the "permanent" stuff) on order. I'll hold off till after it's had a drive or two, listen for rattles.
    * Permatex Red thread-lock can be loosened, with heat.
  20. Dagoba
    Dagoba Junior Member
    25
    Bellingham, WA
    The chain is a pretty good idea, you could always just do a quick tack weld on the last nut/bolt? Though I guess not everyone has a welder laying around...
    DogDaze and Mendel Leisk like this.
