How do I remove RHD footrest/dead pedal
Discussion in 'Gen 2 Prius Technical Discussion' started by Sam66, Jun 13, 2021.
  1. Sam66
    Sam66 New Member
    UK
    ----UK----
    Had my catalytic converter stolen so I need to lift the carpet to replace the O2 sensor.
    All the online info I can find is for the left hand drive version where the sensor wire comes through the passenger footwell. On the RHD version it comes through the driver's side, approximately where there is a black plastic footrest to the left of the brake pedal. I can't see how to remove the footrest so I can lift the carpet and feed the new sensor wire through.
    Does anyone know how to remove it?
  2. Sam66
    Sam66 New Member
    UK
    ----UK----
  3. PriusCamper
    PriusCamper Senior Member
    11,873
    4,817
    Pacific Northwest, USA
    Should be held in by snaps and will pop off. If you do it right you won't break the snaps. :)
  4. Sam66
    Sam66 New Member
    UK
    ----UK----
    Thought that might be the case, do you know where they are located?
    I pried around the edge a bit, it flexed but felt like it might snap the plastic if I forced it.
  5. Sam66
    Sam66 New Member
    UK
    ----UK----
    Just found a picture but I can't post links yet. For anyone else, the snaps are one top, one bottom on the centre line.
