FS: Classic Prius steel rims
Discussion in 'Private Sales' started by mrv, Jul 25, 2006.
  1. mrv
    mrv Member
    121
    ME, USA
    2018 Prius Prime
    updated, see next post.
  2. mrv
    mrv Member
    121
    ME, USA
    2018 Prius Prime
    I have a set of four 14 x 5.5 steel "generic" black rims available for sale. $120 for the set. If you are near 10589 (NY, USA), I am willing to drive about 2 hours for delivery, otherwise you will have to pay shipping (I'd guess around $80 for the set).
    I'm only selling them as a set of 4. (But feel free to break up the set later if you wish. If you can find another owner or three if you only want 2 rims for winter use or for use as a full-sized spare, that's fine, but you do the split of the set.)
    I used the rims on my 2001 Toyota Prius between Nov. 2005 and April 2006 (<5 months), for about 2000 miles. I purchased them last fall (2005) in a tire/wheel package for use with my winter tires (Nokian WR). Since I recently moved out of MA (and do not have tire storage anymore, an unforseen circumstance last fall), I put the 4-season Nokian WRs that were on these rims onto my OEM alloy rims, and disposed of the old/worn OEM Bridgestone Potenza RE92 XL tires.
    New from tirefactory.net these rims were $49.99 each last Nov. 2005
    The specs for the US 2001-2003 Toyota OEM Prius rims are:
    14x5.5" 100mm bolt circle, (not sure if 40 or 45mm offset), 4 hole
    (same wheel as the older 1993-2002 Corolla, and the pre-2004 Echo)
    I don't have the exact specs on these steel rims, but they did work on my 2001 Prius and they are stamped 14x5.5 on the inside of the rims. Only 4 holes, so it's easy to put the wheels onto the car with this generic rim!
    Note: these will not fit on the 2004-current Prius, whose US rims are:
    15x6 JJ, PCD 100mm, 45mm offset, 5 hole
    (same wheel as the Matrix and the newer (2003-?) redesign of the Corolla)
    If you are interested in these other steel rims, let me know, or wait for my next post about them.
  3. mrv
    mrv Member
    121
    ME, USA
    2018 Prius Prime
    Sold.
    BTW: I have learned that some Honda Civics also take this same size wheel.
