Which Prius hack do you do since learning about it?
Discussion in 'Gen 2 Prius Main Forum' started by Kaptainkid1, Jun 29, 2021.
  1. Kaptainkid1
    Kaptainkid1 Active Member
    308
    243
    Los Angeles
    I recently saw a Prius with a dog inside and it was 105 degrees heat outside. I was alarmed and thought man that owner sucks and that dog is going to die. Obviously we tried doors to see if the car would open and it was locked.
    People started to crowd around and I noticed the Prius was making engine noise and noticed the Prius was in ready mode with A/C blasting on. So I convinced the crowd the dog was fine since the AC is cooling the dog.
    A moment later the owner showed up and she slid the key from her SKS Prius fob and preceded to open the door manually. Everyone checked inside to make sure the dog was OK and it was very cold inside the Prius.
    I never ever thought you can lock a Prius when it's in Ready Mode. Since the remote won't activate the locks. I now lock my Prius with the AC on when my Prius is parked outside in the heat. Now I'm loving my new hack getting in my cool car on hot days.
    Only drawback is someone car break the window and steal the Prius because it's on.
    SM-A526U ?
    #1 Kaptainkid1, Jun 29, 2021
    tangerino, Valiant V and Sanchan like this.
  2. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Wow, I did not know that! Might be a useful hack! Are you sure someone can break the window then drive off? My Tundra has remote start and will shut itself off instantly if the door is even unlocked manually with the key.
    The only hack, so far, on our 2017 Prius was turning off that annoying, and loud, backup construction truck beep beep beep!!! (Super loud inside the garage!)
  3. Mendel Leisk
    40,467
    To allay fears of passerby’s: maybe a digital thermometer prominently displayed in the window? Good feedback for the owner too.
  4. ChapmanF
    17,186
    I keep thinking I would like a second hack to make the car undriveable when it's READY but I'm not there.
  5. Kaptainkid1
    308
    243
    Los Angeles
    You can go old school and buy the Club!
    I have one but I'm too lazy to use it anymore. Screenshot_20210629-133536_eBay.jpg
    SM-A526U ?
    #5 Kaptainkid1, Jun 29, 2021
    tangerino likes this.
  6. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    I do the same thing all the time when doing quick errands. I’ll just leave the car in “ready” mode and lock the doors manually with the key. I actually had a locksmith make an extra key for me that I put with my house keys (on a separate key ring), to make this process easier. Best hack ever.
    Valiant V likes this.
  7. Kaptainkid1
    308
    243
    Los Angeles
    Here is another hack that I use for camping. I installed a quick release button inside the trunk lid so when I go camping and I can sleep inside the trunk and I can now pop open the trunk from inside. Cost $10 parts and a great hack.
    Here is a write up I did if you want to know how to.
    https://priuschat.com/index.php?posts/3160579
    20210625_093658.jpg 20210616_103226.jpg 20210616_113021.jpg 20210616_120712.jpg
    SM-A526U ?
    #7 Kaptainkid1, Jun 30, 2021
