Mice infestation
Discussion in 'Prime Main Forum (2017-2022)' started by randerson9248, Jul 1, 2021.
  1. randerson9248
    randerson9248 Junior Member
    66
    SF Peninsula, CA
    2017 Prime.
    I have a dead animal stink inside the car. I opened the hood and found evidence of mice nest. Attached is photo of the cabin filter I removed. Are any parts of the cabin air system easily removed to search for dead rodents.
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    That looks like part of the intake screen on the filter, and it doesn't look like they got through the filter so would be betrween there and the intake. I'd start by disconnecting the intake and replacing that screen while you're in there.
  3. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    If you don't find them, take the car to a mechanic. Once the car is on the lift with a flash light you will find it. Also, adopt a cat.
  4. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    A cat will need you to keep your hood propped open. The can do some real damage under a hood.
  5. bisco
    51,791
    i put baking soda on top of the new filter. took a few weeks for the smell to go away
    Valiant V likes this.
  6. randerson9248
    66
    SF Peninsula, CA
    There are about 4 stray cats in the area. They are lazy, neighbors must be feeding them.
    I have put out mouse traps for about 3 weeks now. Was catching 2 a day at first, now it's been nearly a week and none taking the bait. hopefully they have moved on to a less dangerous environment.
    Smell is the most concern now.
  7. randerson9248
    66
    SF Peninsula, CA
    Thanks for the reply. Where is the intake? Somewhere around the bottom of the windshield?
  8. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    You caught the dumb ones...
    The smart ones are refining their strategy and planning their next assault.
    ....as well as breeding the next generation of still-smarter mice!
    I was going to add earlier that snakes are another way of keeping mice in check. Our property has plenty of both.
    Downside to that is that when you see a shed snakeskin hanging from the undercarriage of your car - suddenly people are not eager to ride in your car.
  9. randerson9248
    66
    SF Peninsula, CA
    They got through (or could have). Attached is a photo of the back side of the filter showing the hole. 20210701_123855.jpg
    SM-N975U ?
  10. Mendel Leisk
    41,234
    Yes. Assuming it’s sim to 3rd gen, you need to remove plastic windshield trim, wipers/motor, and the metal cowl below. 1/4” anti-rodent mesh screwed over the opening does the trick. Maybe apply at end of engine air intake snorkel too; that’s relatively easy.
  11. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    Since you found a nest in the engine compartment you’ll probably want to look for chewed wires/connectors. Hopefully you don’t find any.
    When you pulled the air filter out did you look at the blower wheel? Perhaps you’ll find another nest in there.
  12. randerson9248
    66
    SF Peninsula, CA
    I used a small mirror to look as best that I could. Blower wheel looked clean.
    SM-N975U ?
  13. randerson9248
    66
    SF Peninsula, CA
    How much backing soda? Teaspoon, tablespoon? I don't want to clog the filter with baking soda.
    SM-N975U ?
  14. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    When I had a rodent invasion, the rat made it to the squirrel cage fan, where it was beaten to death when the AC was turned on. I used my cell phone camera to see into the fan and that's how I spotted the corpse. We caught it before it started to stink. I removed the filter and then sprayed Febreze liberally into the opening.
  15. bisco
    51,791
    i just sprinkled it all over the filter. i was more concerned about eliminating the smell than filtering the air, and the filter is loose enough to let air be forced around it.
    i did it twice for good measure, a couple weeks each, then replaced the filter.
    the down side was the baking soda eventually coming out the air vents. it's hard to clean inside the vents. i dodn't pop them out.
  16. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    We don't have a "barn cat" but have been reasonably successful keeping rodents away from our tractor and outside car (the PIP sleeps outside) with mothballs (in a sachet like bag) or Tomcat Rodent Repellent. Either will need to be occasionally replenished.
