Question on Prius Prime 12v Battery Config
Discussion in 'Prime Technical Discussion' started by Michael Wood, Jul 2, 2021.
  1. Michael Wood
    Michael Wood Active Member
    179
    118
    Boston, MA
    2020 Prius Prime
    Does anybody know what that apparatus is that's attached to the positive terminal on the Prime 12v battery? Pic attached.
  2. schja01
    schja01 Senior Member
    1,809
    1,202
    Chicagoland
    2024 Prius
    Limited AWD-e
    The red thing is a cover/insulator the black thing looks like a fusible link. Both are safety devices.
  3. Michael Wood
    179
    118
    Boston, MA
    2020 Prius Prime
    Yes......the black thing that's under the red cover is what I was referring to - looks like a splitter of some kind. And I thought I noticed fuses in it, but I wasn't sure - thanks for the confirmation. I'm not sure if it would be advisable or even possible to use a battery tender on this battery.
  4. schja01
    1,809
    1,202
    Chicagoland
    2024 Prius
    Limited AWD-e
    I use one regularly. The red cover opens by squeezing the two molded arrows. The negative pole is totally exposed.
    Mendel Leisk and Michael Wood like this.
  5. Michael Wood
    179
    118
    Boston, MA
    2020 Prius Prime
    Nice......I'll give the Deltran Jr. a try. Thx.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    The "junior" is a very low capacity unit that really is intended to be used for motorcycles and lawn mowers.
    It probably will be fine for your car........as long as the battery is fresh and healthy.
    But then you don't need one at all if it is driven regularly.
    It will NOT be at all useful to recharge a battery that is mostly DEAD.......probably.
    Michael Wood likes this.
  7. ChapmanF
    16,957
    I typically attach whatever accessory wiring I'm adding to the protected side of that fuse. It's generally a bolted connection and as easy to get to as the clamp itself, so it will take a common ring terminal and make a very convenient and protected attachment point.
    #7 ChapmanF, Jul 2, 2021
  8. Michael Wood
    179
    118
    Boston, MA
    2020 Prius Prime
    I own both the Deltran BatteryTender Jr. and the Plus. Agreed......you need a healthy battery (that you'd like to keep healthy) to use the Jr. on a car battery but I prefer it to the Plus. It takes about 4 hours to flip from red to green and provides a gentle float charge that I trust.
    I only got 4 years out of my 2015 Prius 12v with no maintenance charging. Deltran advertises a 50% increase with maintenance - so that should be 6 years. We'll see.
