Oil Filter Housing Damaged
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by [email protected], Jul 13, 2021.
  1. Racerman15@comcast.net
    [email protected] Junior Member
    30
    San Francisco
    2020 Prius
    The oil change shop apparently significantly over tightened the plastic oil filter cap. On the next oil change the plastic cap shattered when they attempted to remove it. The "technician" dug out the remaining pieces of plastic with a screwdriver. In doing so significantly scratched and chipped the inside of the aluminum housing. Now the O Ring on the cap will not seal and it leaks oil. The aluminum base need to be replaced and I am looking for videos and instructions on replacing it.
  2. rjparker
    9,505
    5,819
  3. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    it’s time to file a lawsuit and buy a Tesla with the winnings.
  4. ChapmanF
    17,186
    It never ceases to amaze me. I recently changed my oil for the first time in a year and a half thanks to pandemic non-driving (yes, yes, I know I should have changed it by time anyway, regardless of miles, but it didn't happen. Anyway.) So the last time that plastic cap was touched was November 2019 and I was wondering if it would give me trouble after that long, but I was the one who tightened it to 18 ft-lb back in 2019, and it came right off without any drama whatever. But all these stories I hear ....
  5. Racerman15@comcast.net
    30
    San Francisco
    2020 Prius
    I will go to this shop today and inspect their torque wrenches. I am not expecting to find one.
    Pdaddy and Steph1972 like this.
  6. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    what happened to “you broke it you bought it” policy?
  7. Racerman15@comcast.net
    30
    San Francisco
    2020 Prius
    How about just a "You broke it You admit it" policy!
    I am looking for any info on replacing the base housing.
    PriusCamper likes this.
  8. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Why aren't you making THEM fix what THEY broke? At the least, tell them you're going to fix it and then they'll have to reimburse you what you spent.
    You can buy the replacement bracket for just $95 at the McGeorge Toyota website (it's $141 retail) and don't replace the oil filter cap with the black plastic, get the aluminum.
    Keep up updated!
    Grit likes this.
  9. ChapmanF
    17,186
    I haven't seen anything that makes it look like a big deal. You buy the thing and two O rings, loosen four bolts, remove the old thing and both its O rings, put on the new O rings and the new thing, and tighten the bolts to 19 ft-lb.
    Some people would replace the thing with the spin-on-style thing as in #2, but I doubt the procedure is any different.
    Strictly speaking, those four bolts are also four of the 25 bolts holding the timing cover in place, and when you're assembling the engine, you're supposed to make sure the thing is installed within 10 minutes of the timing cover itself, and left undisturbed for two hours for the form-in-place timing cover gasket to cure.
    Replacing just the thing might carry a tiny tiny chance of disturbing the FIPG seal there and creating a slight timing cover oil leak, but I don't think I've ever seen anyone report a problem. The FIPG is pretty well cured by now, and if you're not disturbing the other 21 bolts holding the cover in place, I don't see much chance for a problem.
  10. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    good motto but that wont make them financially responsible for repairs though.
  11. rjparker
    9,505
    5,819
    The video above shows how to do it.
  12. Mendel Leisk
    40,467
    I ordered spin-on conversion through Amayama. In Canada ordering parts from the States is "complicated", and if I'm not mistaken Amayama was about half the price, lol:
    Note, the above part no's vary from @rjparker list, but they're just older versions, and 100% compatible. The main piece for example, mine has a sort of tear drop protrusion, at 6 o'clock. Works the same.
    Oil filter for Toyota Prius 3 generation 01.2009 - 11.2011 - Toyota Car & Auto Spare Parts - Genuine Online Car Parts Catalogue - Amayama
    ^ This lilnk is for all the original oil filter components. For me the oil filter cap/housing is $21.07 CDN. There will be shipping on this, so:
    1. Bundle a few other items and it helps defray the shipping cost.
    2. Ensure you only incur one shipping cost, get it all from one country. Typically Japan or United Arab Emirates.
    Link to Priuschat discussion of spin-on conversion:
    Spin on oil filter | PriusChat
  13. PriusCamper
    PriusCamper Senior Member
    11,981
    4,870
    Pacific Northwest, USA
    Lol... Sounds like the place that broke your car is gaslighting you and making you want to blame someone else for their mistake. Even if the cap was on too tight, removing it doesn't cause it to break unless you're incompetent. Ignore their excuses and keep pressing them to repair it! If they won't, fill out a form on the Better Business Bureau website, that usually gets the boss/owner's attention in ways that other efforts won't.
  14. Mendel Leisk
    40,467
  15. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Racerman, I highly recommend ordering the conversion kit that rjparker showed you. Its easy, simple and the oil filter is much easier to remove. I did the conversion and I love it! Hated the plastic cannister.
    Paul E. Highway likes this.
  16. tony_2018
    tony_2018 Member
    225
    66
  17. Paul E. Highway
    Paul E. Highway Active Member
    206
    129
    Hawaii
    +1 on the spin on filter conversion. Takes about 10 minutes. I got the parts from Amayama, too. When I bought my 2010 used with 115K miles the filter was welded on by a Jiffy Lube chimpanzee-had to get dealer to remove it. I tried with a long breaker bar and it would not budge. Spin on filter is fast and easy!
    Montgomery likes this.
  18. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,343
    2,337
    Taylors, SC
  19. xliderider
    xliderider Senior Member
    8,032
    3,211
    Honolulu, HI
  20. ASRDogman
    ASRDogman Senior Member
    7,115
    3,713
    Since THEY damaged it, THEY need to replace it, at no cost to you.
    Steph1972 and Grit like this.
