My 2012 prius over heating
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Chuba, Sep 27, 2021.
  1. Chuba
    Chuba Junior Member
    45
    Nigeria
    I changed the engine and transaxle of my prius 2012 for rattling and knocking noise. Now the car is over heating. If i start the car and drive for about 15 minutes. The car will not on its own go off again. At stops the engine stays on and the two fans keeps blowing. The engine is suppose to go off at stops. I noticed that the down holes of my radiator pipe is always cold. The big pipe coming from the engine water to radiator. The engine water pump works fine. I have changed the thermostat. The car has 144,000 miles on it. There is no error codes. Please what could be the issue?
    51,897
    thermostat, did you test it?
  3. ChapmanF
    18,149
    Do you see coolant flowing back to the reservoir through the hose that connects at the top?
  4. ttou68
    ttou68 Active Member
    351
    211
    jzchen likes this.
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Sounds like a Gen 4 implant into a Gen 3...
  6. Chuba
    Chuba Junior Member
    45
    Nigeria
    It hardly happen.
    Even when I wasn't having the over heating. I don't see it
  7. Chuba
    Chuba Junior Member
    45
    Nigeria
    The same complete prius engine. 2zr
  8. Chuba
    Chuba Junior Member
    45
    Nigeria
    It's gen 3 engine. But year model is unknown. It's 2010 to 2015 prius engine swap
  9. Chuba
    Chuba Junior Member
    45
    Nigeria
    I just removed the thermostat. Still the engine stays on after 15 minutes of driving.
    I'm beginning to think the issue is my ac.
    This morning I was driving without the AC. The car did not give me any issue. Within 5 seconds I switched on my AC, the engine can on upon I still have enough battery charge.
    When my engine was changed water poured inside the black electrical socket of the compressor.
    We started the car then the AC refused oning. It was after we cleaned the water that the ac switched on.
    Could it be that the ac is now damaged causing the engine to stay on?
  10. Mendel Leisk
    41,406
    The connector on top of the AC compressor right? That's like a little cup, catches water just fine, and will short-out or corrode the pins instead. Hard or impossible to repair too.
  11. bisco
    51,897
    hard to believe there are no codes...
