HID to LED conversion
Discussion in 'Gen 2 Prius Main Forum' started by Lloyd-ss, Jan 14, 2018.
  1. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    And the shop may only spend an hour doing it which is fine with me.
    Lloyd-ss likes this.
  2. Mirage42
    Mirage42 Member
    30
    27
    Russia Siberia
    If you want to see a video of a review of only light bulbs, and not all products, then I can disappoint you. The gen2 reflector headlight is outdated physically, morally and technically. With a new headlight, the result will suit you on any bulb. And nothing will help the old headlight, only good lenses.
    Perhaps you have organizations that are engaged in the conversion of headlights, they should be aware of.
  3. Lloyd-ss
    Lloyd-ss Member
    85
    85
    Ivy, VA
    Four Touring
    Another,
    ok, I think I understand your POV now, and it certainly makes sense. It sounds like what "tirerack.com" does. They ship the tires to you with a great selection and prices, and then connect you with a network of certified local installers. I've used their network and it works.
    Another likes this.
  4. Lloyd-ss
    Lloyd-ss Member
    85
    85
    Ivy, VA
    Four Touring
    I love your comment. So very true, and with a sense of humor.
    Lloyd
    Mirage42 likes this.
  5. Lloyd-ss
    Lloyd-ss Member
    85
    85
    Ivy, VA
    Four Touring
    My 2007 only has 110k miles on it, and it is still a great car. Zero major repairs, and the only 2 disappointments have been the headlights, which are now fixed, and the expensive GPS update discs. Rather than update the GPS, I just use a Garmin. If the discs were half as expensive, I would buy one today. Toyota just went past my threshold of pain on that one.
  6. Mirage42
    Mirage42 Member
    30
    27
    Russia Siberia
    I agree with you, Prius Excellent reliable car. And the headlights can be corrected, in another topic I showed how I did it. LED headlights | Page 4 | PriusChat
  7. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    What about a phone mount and google maps or another similar app?
  8. Lloyd-ss
    Lloyd-ss Member
    85
    85
    Ivy, VA
    Four Touring
    You are right. Hard to beat a zero-cost solution. being a wee bit older :ROFLMAO: I am still learning what my phone is capable of.
  9. Lloyd-ss
    Lloyd-ss Member
    85
    85
    Ivy, VA
    Four Touring
    I just watched the video and looked at the pictures you referenced. Very interesting. In the video the horizontal cut-off of the light beam looks very sharp, with all of the light staying below eye level, where it should be. Also, I was surprised by how much light you could see even when driving in an area that had street lights.
    It looks like you kept the old headlight housings, and installed totally new internal light assemblies, using some bolts and lock nuts. The light assemblies are about 100mm in diameter, and 100mm long? How does the hi beam/low beam work? Does it have a mechanical shield that covers the bulb for low beam? I always thought that was a really weird way to do low/high beam. Unnecessarily complicated.
    But the lights in my Prius don't have capability to power 2 separate light circuits??? How does yours work?
    SFO likes this.
  10. Mirage42
    Mirage42 Member
    30
    27
    Russia Siberia
    All your guesses are correct. Module diameter 3 inches. Koito BI LED module operation is similar to standard HID. If everything is halogen, then you need to put a jumper in the relay that switches the near / far so that the near one is always included as HID. The most difficult thing is precise mechanical work. Also buy Koito bi led at a good price.
  11. Another
    1,819
    517
    Naples, Florida
    It amazes me that with all of the people who supposedly would like updated disks that Toyota does not release the map interface software to open source developers. It is not rocket science and the alternatives are a PiTA to mount over the MFD which is the place the maps should be.
  12. Gretchen1015
    Gretchen1015 Junior Member
    Thank you for posting! The pictures really help too. I am a lurker too, with a 2008 Toyota Prius with those dreaded HID's. I think I will try the conversion--my HID's have been nothing but trouble, and very expensive too. I'm curious how your LED's have held up since 2018?
  13. Another
    1,819
    517
    Naples, Florida
    audiodave likes this.
  14. Lloyd-ss
    Lloyd-ss Member
    85
    85
    Ivy, VA
    Four Touring
    LED HEADLIGHT UPDATE AFTER 5 AND 1/2 YEARS
    I did the original HID to LED conversion almost 6 years ago (Jan 2018).
    But after about 3 years (Oct 2021) one of the LED lamps stopped and I replaced both of them with some newer LED lamps, in post #112.
    It is now Oct 2023, 3 more years later, and the newer LED headlamps are still working fine.
    I find it a bit ironic that my 2016 Tacoma is still going strong with its original headlamps, now going on 7 years.
    Lloyd
    #134 Lloyd-ss, Oct 18, 2023
    TomHaraka, audiodave and strawbrad like this.
  15. TomHaraka
    TomHaraka Junior Member
    Any new/live links to conversion kits? My 2005 w/435k miles continues to kill the RH HID bulb (last replacement was 2 months ago). The AILEO one you posted about does not appear to be available anymore.
    I'm probably more interested in a conversion that comes with its own ballast, in case my original HID one is now bad. And of course, I'd also like to not have radio interference.
    Thoughts? Ideas? Links?
    Also, any cheap sources for replacement dome dust covers? I've managed to shear most of the tabs off mine.
  16. TomHaraka
    And... This thread refers to D4 bulbs, but I could swear that my 2005 Prius has D2 HID ones. Just want to check which LED kit to get.
  17. talonts
    talonts VFAQman
    468
    76
    2004-5 use D2
    2006-9 use D4
    Though most of the LED kits will probably work with both, as I believe they bypass the ballast and their differing voltages.
    #137 talonts, Feb 24, 2024
  18. Natane
    Natane New Member
    nevada
    Please tell me there is a video somewhere that I can follow?
  19. Lloyd-ss
    Lloyd-ss Member
    85
    85
    Ivy, VA
    Four Touring
    Sorry, my google is broken, see if yours works. I posted plenty of step-by-step pictures at the beginning of this topic
    But actually, since I originally posted, I have totally converted the headlamp system to halogen instead of the original HID. I went through a couple of different sets of LED lamps, but never did find any that were bright enough. I think a big part of the problem was that the clear plastic of 18 year old headlight assemblies was all frosted and dull and blocked a lot of the light output.
    So it is now converted back to a 2007 halogen system, (NOT HID), and I LOVE it. The lights are much, much, brighter. After having done the previous LED conversions, it wasn't too difficult, but it wasn't easy, either. There are threads on the forum saying conflicting information, but I went along with what made the most sense.
    I bought the parts from Amaz## and the parts were $121 for the pair of new headlamp lens assemblies (the great big things),
    $12 for the pair of halogen light sockets, $20 for a pair of Hella halogen bulbs, and $11 for a pair of relays and sockets. Total was $164 for the entire project.
    One issue is that the headlamp lens assemblies do not come with the big 4" diameter covers that go under the hood. I ended up making some out of plastic because they were ridiculously expensive to buy.
    I did this 3 months ago and still had the cheesy schematic laying around. I have part numbers, etc, and could improve the schematic, but tell me what you are trying to do.
    Lloyd
    BrokenPipe likes this.
