2012 Prius v Wagon Front Seat Mounting Bolts -14mm, What Pitch?
Discussion in 'Prius v Accessories and Modifications' started by Air_Boss, Nov 9, 2021.
  1. Air_Boss
    Air_Boss Senior Member
    4,197
    1,183
    New Yawk
    Anyone know what is the bolt pitch of 2012 Prius v Wagon Front Seat Mounting Bolts?
    They are 14mm bolt heads, but what pitch?
    Thanks.
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I hate to not have an answer I just went to the parts.toyota.com site and found 90119A0304. They MSRP at $1.47.
    My local Home Depot has the bolt and nut sizer with thread pitch....
    REVVL V+ 5G ?
  3. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    From Albany County Fasteners:
    "For metric fasteners, thread pitch is used in place of TPI. The distance is also measured in millimeters. To measure thread pitch, use a caliper and measure from the peak of one thread to the next."
    In a pinch, you can try to use a ruler with metric markings to see if the threads are 1mm, 1.5mm, 2mm, etc pitch.
  4. Mendel Leisk
    41,406
    Take out one of the bolts you have, check fit with a metric nut (at hardware store), then (assuming you find a fitting one) get appropriate bolts.
    Rbjr and jerrymildred like this.
  5. Air_Boss
    4,197
    1,183
    New Yawk
    Good suggestions, all. Thanks!
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,463
    2,423
    Taylors, SC
    Any bolt with a 14mm hex head on a Toyota product will be M10x1.25 pitch thread. Toyota conforms with the J.I.S, or Japan Industrial standard.
  7. Air_Boss
    4,197
    1,183
    New Yawk
    Good to know. Thanks!
    Rbjr and Georgina Rudkus like this.
  8. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    Which begs the question, why do you need new seat mounting bolts? They don't get much wear and tear on them.
  9. Air_Boss
    4,197
    1,183
    New Yawk
    I am considering raising the front legs of the passenger/SO seat by 1-1/2 inches using a machined riser, which would require longer bolts. Still in the safety engineering stage, but think the bolts are going to have to be SAE Grade 8 (Metric Grade 10.9).
  10. Georgina Rudkus
    3,463
    2,423
    Taylors, SC
    Grade 10.9 J.I.S flange bolts are readily available from several vendors on eBay. I have a sizeable supply of them that I have acquired over the past 10 years. Jinn Herr is the most prominent supplier of these bolts. They are marked with with the raise letters "JH." on their heads. "WT" is another supplier.
    My favorite is an assortment of these bolts in varying sizes an lengths with matching flange nuts in a nice compartmented steel box for around $100 with free shipping. All are ISO grade 10.9. These really come in very handy, A few ones of these bolts pays for the whole box compared to searching for and buying them in small lots individually.
    All of them match the thread sizes and hex wrench sizes of the bolts used on all Toyota vehicles.
    Everyone who owns and works on his or her Toyota should buy and have this kit on hand. A good example is the M6x1.0c30mm flange bolt that holed the coil on to the car. That is included with this kit. An auto parts store might have this bolt but not with the flange head.
    #10 Georgina Rudkus, Nov 9, 2021
    Air_Boss likes this.
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Rbjr likes this.
  12. Georgina Rudkus
    3,463
    2,423
    Taylors, SC
    jzchen likes this.
  13. Air_Boss
    4,197
    1,183
    New Yawk
    jzchen likes this.
  14. Mendel Leisk
    41,406
    In the States McMaster Carr is one go-to name for bolts, and various hardware bits.
  15. gromittoo
    719
    288
    philadelphia
    2013 Prius v wagon
    I am just over six feet. With my 2017 four's fully adjustable seat, I can raise the front of the seat to make it more comfortable. I would like to be able to raise the front of the drivers seat in my 2013 two as well. The back of my legs just above the knee need support. I typically drive Uber for 13 hour stretches, and my knees do hurt after a while.
    Rbjr and Air_Boss like this.
  16. Air_Boss
    4,197
    1,183
    New Yawk
    We are both taller, and the SO is long of leg, so that’s where the attention and relief are directed. I will give ride reports after installation and use!
    jzchen likes this.
  17. gromittoo
    719
    288
    philadelphia
    2013 Prius v wagon
    If other family members need to drive the car, then it would be helpful to make this new "adjustment" to the seat quickly and easily reversible. Lets get the data on if it actually helps first.
  18. Air_Boss
    4,197
    1,183
    New Yawk
    This is a passenger seat only mod. SO prefers not to drive the v.
  19. Air_Boss
    4,197
    1,183
    New Yawk
    Well, the verdict is in, and the 1.5” lift was a success. The added thigh support made all the difference. SO Approved!
    jzchen likes this.
  20. rjparker
    10,135
    6,298
    I bought an extend a seat bracket kit back in the day.
