120V plug under hood?
Discussion in 'Gen 4 Prius Main Forum' started by Mattedfred, Nov 9, 2021.
  1. Mattedfred
    Mattedfred New Member
    Cambridge, Ontario Canada
    Hello,
    Sorry for the newbie first post and stupid question but I've gone through the owner's manual, tried Google and searched this site but haven't found the answer.
    What's that 120V plug for that's under the hood on the passenger side near the headlight?
    Being from Canada it looks like it would be for a block heater but I can't see where the wiring routes to the engine.
    Appreciate any assistance.
    Ted
    2017 Prius Base
  2. Tideland Prius
    16,435
    Hard to say without a photo but that's typically an engine block heater.
  3. Mattedfred
    I’m not with the car right now but the wiring doesn’t appear to go to the engine block. Just imagine a 120V plug sitting there at the front passenger side of your engine. Anyone with a Prius 2017 or otherwise have this?
  4. bisco
    51,045
    i vote heater too
  5. Mattedfred
    Here’s a photo of the plug. While it looks like a block heater plug, it doesn’t route to the engine block. It routes to another electrical connection. See next image below.
  6. Mattedfred
    This is the electrical connection mentioned in my previous post. Surely another Prius owner has the same plug and knows what this is?
  7. Tideland Prius
    16,435
    Yeah you’re right. That’s weird. That looks aftermarket to me but I don’t know what would require a household outlet. An engine oil pan heater maybe?
    My engine block heater was dealer installed but went into the engine block and it didn’t have that extra controller in the second photo.
    Mattedfred likes this.
  8. Mendel Leisk
    40,504
    On-board charger for the 12 volt battery? Except battery's on the driver's side.
    @Tideland Prius, should this be in 4th gen maintenance and troubleshooting, not newbie intro stuff?
  9. Mattedfred
    I don't believe our owner's manual mentions one. I've posted this in the section you mentioned. My apologies. Surely we're not the only one's with this plug?
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    An engine heater does not have to heat the block directly.
    There are several ways to accomplish it via the coolant too.
    And it is also possible that it connects to BOTH an engine heater and a 12 V battery tender.
    Where did you GET the car ?
    Maybe you should ask them ??
  11. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    Doesn't look "normal" - but I'm in Australia where everything is upside down.
    There has been talk by a few people on this FORUM about running a CPAP Machine needing Mains voltage. Possible?
  12. Mattedfred
    We purchased the vehicles used from an out of town Toyota dealership last year. I assumed I'd get a way quicker answer via this forum. Meanwhile, I've emailed our sale representative. I attempted to repost this in the 4th gen technical section but I guess that wasn't approved.
  13. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    I have a 2017 four touring in the U. S. and don't have that. It must be after market or a Canada thing.
    Inspectorman likes this.
  14. sam spade 2
    7,035
    2,798
    2017 Prius c
    Good luck with that.
    It is likely that the only way you will get a good answer is to have a shop trace out the wires and see what they are connected to.
    Having it up on a rack where both the top and bottom of the engine is accessible should make the process much easier.
  15. fuzzy1
    10,335
    Those black plastic zip ties holding the electrical enclosure in place scream "aftermarket".
  16. CooCooCaChoo
    CooCooCaChoo Senior Member
    951
    533
    Cow-lee-fornia
    2023 Prius
    I would suggest using an extension cord and hook it up to see what happens, but that is risky.
  17. Tideland Prius
    16,435
    I moved this thread to the Gen 4 section already.
    Mattedfred and alanclarkeau like this.
  18. bisco
    51,045
    iwould be willing to plug it in, just for the thrill :eek:
  19. CooCooCaChoo
    951
    533
    Cow-lee-fornia
    2023 Prius
    ^^^ Make sure you have full comprehensive coverage before you plug it in. If it melts down at least you'll be covered.
  20. Mattedfred
    Thanks for moving the thread. I wasn't aware that had happened.
    Still waiting to hear back from the dealership.
    Meanwhile, I'm going to email the photos to the service rep at our local Toyota dealership and see if he can quickly get us an answer.
    Still can't believe we're the only people that have read this thread that have this plug.
    Tideland Prius likes this.
